Top 5 Steering Fixes for GMT400 (OBS 88–98)
If your truck wanders all over and feels like a boat, start here.
1. Idler + Pitman Arm
This is usually the main problem.
Slop before the truck reacts
Wandering down the road
Clunking over bumps
Don’t cheap out here.
Run MOOG Problem Solver or better and do:
Idler arm
Idler bracket
Pitman arm
If the center link moves up/down at the idler, it’s done.
2. Steering Box
Don’t jump straight to replacing it.
Try this first:
Loosen jam nut
Snug the adjuster
Back it off slightly
If you crank it down, it’ll bind and won’t return to center. Full guide here.
Still sloppy after everything else?
Then look at RedHead or Borgeson.
3. Rag Joint / Steering Shaft
This one gets ignored a lot.
Feels rubbery
Slop between wheel and box
Weird feedback over bumps
Cheap fix:
- Replace rag joint
Better:
- Swap to a U-joint style shaft. 1988-1994 Guide here.
Big difference in feel.
4. Front End Wear
If it’s all original, it’s all worn.
Check:
Tie rods
Center link
Ball joints
Don’t piece-meal it if everything is tired.
Do it once:
Inner/outer tie rods
Sleeves
Center link
Then align it.
5. Alignment + Tires
This gets overlooked constantly.
Add a bit more caster (within spec)
Make sure toe is actually correct
Not just “green on the screen”
Bad tires will make a good front end feel like junk.
Order to fix it
Idler/pitman
Rag joint
Box adjustment
Front end refresh
Alignment + tires
