8.1 Vortec L18 DBW Pinouts: 2001–02 vs. 2003–06 Harness Guide
There is no single universal 8.1 L18 DBW pinout. First determine whether the donor is a 2001–2002 pre-MCE light-duty system or a 2003–2006 MCE light-duty system. Everything downstream — PCM, TAC, pedal, throttle, cam/crank orientation — follows from that. This is the deep-reference version; the full researched article with source notes and every table lives on the blog.
Scope: factory-documented 2001–2006 light-duty GMT800 pickups/SUVs (Silverado/Sierra 2500HD & 3500, Suburban/Yukon XL 2500, Avalanche 2500 where L18-equipped). Medium-duty is shown only for comparison. Express/Savana, Workhorse, marine, and industrial are separate systems — do not wire them off these tables.
:warning: Technical and safety notice: GM wiring varies by model year, platform, transmission, RPO, calibration, and connector orientation. Confirm the donor VIN, PCM/TAC/pedal/throttle family, circuit numbers, and terminal-face orientation against the applicable factory documentation, and perform continuity testing before applying power. Incorrect wiring can cause a no-start, Reduced Engine Power, component damage, or unsafe operation. Use this as a research reference, not a substitute for the donor-year service manual.
Connector orientation matters. A schematic cavity label is not automatically a physical terminal-face view. Confirm the latch, key, cavity marks, circuit number, and continuity on the actual donor connector before moving terminals.
Four things to photograph or record first
  1. PCM label + connector colours — blue/red = P01 (2001–02), blue/green = P59 (2003–06).
  2. TAC module label + its two connectors — this tells us pre-MCE vs. MCE (and rules out a commercial module).
  3. Pedal part number — 15318071 is the light-duty pedal; 15326842 is medium-duty, which does not belong here.
  4. Throttle connector + hardware — split motor + separate TP connector = pre-MCE; single 8-way integrated body (15326836) = MCE.
Also grab the VIN, model year, production date, engine RPO (L18), transmission RPO, PCM service number, PCM hardware number, OS/calibration IDs (scan tool), TAC label, ground locations, splice packs, and underhood fuse-panel labels. Keep the pedal-to-TAC firewall sub-harness intact.
Quick family ID
2001–02 pre-MCE LD 2003–06 MCE LD
PCM P01 blue/red P59 blue/green
Throttle Split motor 12077900 + 6-way TP 12162261 Integrated 8-way 15326836
TAC family Pre-MCE LD (C1 12191065 / C2 12177081) MCE LD (J1 12191065 / J2 12177081)
Pedal 15318071 (pre-MCE circuits) 15318071 (MCE circuits)
Cam/crank outer cavities Reversed vs. LS truck comparator Match LS truck comparator
Medium-duty warning: 2003/04 C-series uses TAC 25311787, J2 12065425, pedal 15326842, split throttle. 2005 C-series uses integrated 15326836 but pedal 15326842 with tool-line pins. Same throttle PN ≠ same harness. Don’t mix them.
Year and architecture matrix
Family Platform ETC control Pedal Throttle Status
2001–02 pre-MCE LD GMT800 pickup/SUV Separate TAC family (P01) 15318071 Split motor + separate TP Separate LD family; do not merge with MCE
2003–06 MCE LD GMT800 pickup/SUV Light-duty J1/J2 ETC (P59) 15318071 Integrated 15326836 Factory-proven
2003/04 medium-duty C-series TAC 25311787 15326842 Split throttle Factory-proven, materially different
2005 medium-duty C-series Commercial TAC family 15326842 + tool lines Integrated 15326836 Factory-proven, still not light-duty
Express/Savana, Workhorse, marine, industrial Separate Do not infer Do not infer Do not infer Excluded — separate docs required
P01 vs P59
  • Blue/red = P01 (2001–02). Blue/green = P59 (2003–06). That family ID is reliable.
  • Service numbers are not universal. 12200411 (P01) and 12576106/HW12570558 (P59) are common leads, not a guarantee for every VIN. Read the donor label and do a VIN-based ACDelco/SPS calibration lookup.
  • A non-L18 P59 is only a hardware base after a complete compatible L18 OS/calibration is loaded. No blind segment swap.
  • What must stay together: PCM hardware supporting the full L18 cal; TAC + pedal + pedal-to-TAC sub-harness within one verified family. Same donor is safest.
  • The only proven cross-family throttle match is 15326836 between MCE LD and 2005 MD — that proves one assembly’s electrical layout, not full ETC-system interchange.
Full pre-MCE (2001–2002) tables
Evidence note: the pre-MCE connector-end-view detail is professional reproduction of GM service information (CHARM, 2002 K2500 L18), corroborated against the exact L18 schematic set — Grade B. GM Upfitter does not publish a free 2001–2002 connector-end-view package; confirm on your donor. Factory context: GM light-duty archive.
Split throttle — TAC motor connector 12077900 (terminal face)
Cavity Circuit Colour Function Dest
A 582 BRN TAC motor 2 TAC C1-8
B 581 YEL TAC motor 1 TAC C1-16
Split throttle — 6-way TP connector 12162261 (terminal face)
A 416 GRY TP1 5V ref TAC C1-2
B 452 BLK TP1 low ref TAC C1-3
C 485 DK GRN TP1 signal TAC C1-1
D 1688 LT BLU/BLK TP2 5V ref TAC C1-9
E 1704 BLK/WHT TP2 low ref TAC C1-10
F 486 PPL TP2 signal TAC C1-11
Pedal 15318071 — pre-MCE (terminal face, A–K)
Cav Circuit Colour Function TAC
A 1273 GRY APP/PPS3 low ref C2-A
B 1272 PPL APP/PPS2 low ref C2-B
C 1162 LT BLU APP/PPS2 signal C2-C
D 1274 TAN APP/PPS2 5V ref C2-D
E 971 BRN APP/PPS1 low ref C2-E
F 1161 DK BLU APP/PPS1 signal C2-F
G 1164 WHT/BLK APP/PPS1 5V ref C2-G
H Factory unused
J 975 YEL/BLK APP/PPS3 5V ref C2-J
K 1163 DK GRN APP/PPS3 signal C2-K
TAC C1 12191065 — pre-MCE (terminal face, 16-pin)
Pin Circuit Colour Function Dest
1 485 DK GRN TP1 signal TP C
2 416 GRY TP1 5V ref TP A
3 452 BLK TP1 low ref TP B
4 84 DK BLU Cruise set/coast steering/PTO (opt)
5 87 GRY/BLK Cruise resume/accel steering (opt)
6 1320 LT BLU Brake/stop input stoplamp/CHMSL
7 1339 PNK IGN1 feed 15A ETC fuse
8 582 BRN Motor 2 throttle motor
9 1688 LT BLU/BLK TP2 5V ref TP D
10 1704 BLK/WHT TP2 low ref TP E
11 486 PPL TP2 signal TP F
12 1061 ORN/BLK TAC serial A (UART/ETCA) PCM
13 774 DK BLU/WHT TAC serial B (UART/ETCB) PCM
14 397 GRY Cruise on/off steering/PTO (opt)
15 451 BLK/WHT TAC ground ground dist
16 581 YEL Motor 1 throttle motor
TAC C2 12177081 — pre-MCE: mirrors the pedal table above (C2-A…C2-K land on pedal A…K); circuit E = 971 (BRN), J = 975 (YEL/BLK).
Cam/crank — pre-MCE (terminal face)
Sensor A B C Conn PN
CMP supply 631 RED → C2-39 low ref 632 PNK/BLK → C1-61 signal 633 BRN/WHT → C1-73 12129946
CKP supply 1867 LT GRN → C1-2 low ref 1868 YEL/BLK → C1-21 signal 1869 DK BLU/WHT → C1-12 15324165
P01 factory-used core circuits (2001–02): grounds 451 (C1-1/C1-40/C2-1/C2-40); constant B+ 440 ECM B 20A (C1-20/C1-57); IGN1 439 ECM I 10A (C1-19); ign-state 1020 (C1-75); TAC serial 1061 (C1-14) / 774 (C1-15); CKP 1867/1868/1869 (C1-2/C1-21/C1-12); CMP 631/632/633 (C2-39/C1-61/C1-73); MAP 432 (C2-32); 5V ref 597 (C2-48); low ref 469 (C2-54); ECT 410 (C1-74); IAT 472 (C1-25); MAF 492 (C2-31); VSS 822/821 (C2-20/C2-21); Class 2 1049 (C1-58); MIL 419 (C2-46); KS 496/1876 (C1-51/C1-11); plus injector, coil and fuel-pump-relay driver groups on the exact sheets. Factory-used list, not a complete terminal-face map — unlisted cavities are not implied unused.
Full MCE (2003–2006) tables
Integrated throttle body 15326836 (terminal face; GM Upfitter printed page D-118 / PDF page 214, schematic K33021a_010_01)
Cavity Circuit Colour Function TAC
A 581 YEL Motor 1 J1-16
B 1704 BLK/WHT TP2 low ref J1-10
C 582 BRN Motor 2 J1-8
D 452 BLK TP1 low ref J1-3
E 1688 LT BLU/BLK TP2 5V ref J1-9
F 486 PPL TP2 signal J1-11
G 485 DK GRN TP1 signal J1-1
H 416 GRY TP1 5V ref J1-2
Pedal 15318071 — MCE (terminal face; D-120/D-121). Watch cavities E and J vs. pre-MCE.
A 1273 GRY PPS3 return J2-A
B 1272 PPL PPS2 return J2-B
C 1162 LT BLU PPS2 signal J2-C
D 1274 TAN PPS2 5V ref J2-D
E 1271 BRN PPS1 return J2-E
F 1161 DK BLU PPS1 signal J2-F
G 1164 WHT/BLK PPS1 5V ref J2-G
H Factory unused
J 1275 YEL/BLK PPS3 5V ref J2-J
K 1163 DK GRN PPS3 signal J2-K
TAC J1 12191065 — MCE (terminal face; D-119): same as pre-MCE C1 except ground pin 15 = circuit 550 (not 451). Serial pair 12/13 = 1061/774; IGN1 pin 7 = 1339; brake pin 6 = 1320; Motor 1 pin 16 = 581; Motor 2 pin 8 = 582. TP pins 1/2/3/9/10/11 = 485/416/452/1688/1704/486.
TAC J2 12177081 — MCE: J2-A…J2-K land on pedal A…K; circuit E = 1271 (BRN), J = 1275 (YEL/BLK).
Cam/crank — MCE (terminal face; engine controls D-53–D-64, CMP/CKP on D-63)
CMP signal 633 BRN/WHT → J1-73 low ref 632 PNK/BLK → J1-61 supply 631 RED → J2-39 12059595
CKP signal 1869 DK BLU/WHT → J1-12 low ref 1868 YEL/BLK → J1-21 supply 1867 LT GRN → J1-2 15324165
P59 factory-used core circuits (2003–06, GM pages): grounds J1-1/J1-40/J2-1/J2-40 (D-64); B+ J1-57 group (D-56/D-64); VIGN1/VIGN0 J1-75/J1-20 (D-56); CKP J1-2/J1-21/J1-12 (D-63); CMP J2-39/J1-61/J1-73 (D-63); ECT J1-74, MAP J2-32, 5V/return J1-48/J1-54, oil-press J1-60 (D-53); IAT J1-26, MAF J1-56/J1-11 (D-55); Class 2 J1-58/J1-59, fuel-pump relay J1-47, MIL J1-46 (D-56/D-58); injectors J2-55–J2-62 and coils on J1 (D-61/D-62); knock J2-19/J2-20 (D-63). Factory-used list, not a complete terminal-face map.
Cam/crank warning
Swap the outer cam/crank cavities only when adapting the common Gen III LS truck connector layout to a verified 2001–2002 pre-MCE L18. On 2003–2006 MCE L18 the layout already matches the LS truck comparator, so do NOT swap. Wire supply-to-supply, low-ref-to-low-ref, signal-to-signal — by circuit function and PCM destination, not by colour or cavity letter. Reversing supply and signal gets you a no-start and cam/crank codes; don’t power up a miswired sensor.
Full tables, diagrams and the complete source list: GM 8.1L Vortec L18 Drive-by-Wire Wiring: 2001–2002 vs. 2003–2006 - FullSizeChevy.com
Standalone minimum circuits (grouped)
  • Required to crank/start/run: PCM constant B+ (fused); switched ignition + state; multiple PCM grounds (keep sensor low-ref off them); cam + crank (right year); 8 injectors + feed; 8 coils + feed; fuel-pump relay control (pump on its own protected feed); TAC 15A ETC feed + clean TAC ground; TAC serial pair 1061/774; pedal + throttle circuits (don’t mix eras); DLC 2/4/5/16.
  • Required for safe DBW/drivability: brake input 1320 (do not omit if you want normal factory DBW behaviour); MAF/IAT, MAP, ECT; front O2s; VSS; range/PNP.
  • Transmission-dependent: 4L80E shift/TCC/pressure/temp/range/VSS or Allison serial + torque interface (don’t treat Allison as a 4L80E pinout).
  • Emissions-dependent (cal + legal review to delete): rear O2, EVAP, AIR.
  • Optional: A/C request/clutch, tach, gauges, fan outputs, PTO/cruise.
  • Must not be casually removed: sensor low references (never to actuator/chassis ground); TAC brake + serial circuits.
This is a minimum-retained-circuit map for the verified family, not a universal plug-and-play standalone manual. Exact needs are application-, transmission-, and emissions-dependent.
Fuse and relay (documented values only)
Load Fuse Rating Application
PCM constant feed ECM B (UH BEC) 20A LD L18/Allison feed
PCM ignition feed ECM I 10A 2001–02 LD
Ign state/control IGN0 / IGN1 10A each 2001–02 LD
TAC/ETC module ETC / ETC_FD 15A 2001–06 LD (MD also 15A)
Cruise CRUISE 10A 2001–02 LD
Veh stop VEH STOP 10A 2001–02 LD
Stop lamps STOP LPS 20A 2001–02 LD
Injector bank 1/2 INJ1 / INJ2 15A each 2003–06 MCE LD
Coil, O2-heater, fuel-pump, transmission, A/C, and fan ratings are donor-specific — pull them from the exact donor fuse block. Don’t invent universal values.
Reduced Engine Power — diagnostic order
  1. Confirm donor family + component pairing → 2. Read all DTCs → 3. Battery/charging voltage → 4. PCM + TAC feeds → 5. PCM + TAC grounds → 6. Dedicated low-reference circuits → 7. TAC serial 1061/774 → 8. APP tracks → 9. TP tracks → 10. Throttle-motor circuits → 11. Brake input → 12. Cam/crank wiring by function → 13. Connector tension/terminal damage → 14. PCM OS/calibration compatibility → 15. Transmission/VSS/range inputs.
Relevant DTC families: P1120/P1125 (APP), P1220/P1221 (TP/APP correlation), P1516 (TAC performance), P2101/P2119-class, TAC comm codes, 5V-ref codes, P0335/P0336 (CKP), P0340/P0341 (CMP), P0016/P1345 (cam/crank correlation), P0500/P0502/P0503 (VSS), brake rationality, P0705/P0850 (range). Confirm exact definitions in the donor-year SI — don’t apply late DTC wording to 2001–02 systems.
Medium-duty comparison (not for light-duty builds)
  • 2003/04 C-series L18: TAC 25311787, J2 12065425, pedal 15326842, split throttle — GM Upfitter, 2003 & 2004 Medium Duty C Series Electrical, printed pages D-192–D-193 (PDF 260–261): GM PDF.
  • 2005 C-series L18: integrated 15326836, pedal 15326842 with tool-line pins — GM Upfitter, 2005 Medium Duty C Series Electrical, printed pages D-127–D-128 (PDF 202–203): GM PDF.
The shared throttle assembly 15326836 proves only that one assembly’s electrical layout — not full ETC-system interchange.
Explicitly excluded platforms
Express/Savana, Workhorse, motorhome chassis, marine (MEFI-4), industrial, crate-engine packages, and aftermarket control systems all require separate factory documentation and are outside these light-duty pinout tables. A shared engine code or a connector that physically plugs in does not prove wiring compatibility.
Factory documentation
Evidence grades: Grade A = official GM (Upfitter/Body Builder/SI/ACDelco). Grade B = licensed reproduction of GM SI (CHARM/Mitchell/ALLDATA) for the 2001–02 connector-end views. No forums, marketplace listings, or social posts are used as proof.
Related 8.1L Vortec technical threads
Still unresolved (help close these)
  • Exact donor PCM service number / OS / calibration by VIN (family split is safe; a universal service-number matrix is not closed).
  • Complete physical P01/P59 terminal-face connector maps.
  • 2001–2002 connector-end views from a free official-GM source (current detail is Grade B professional reproduction).
  • Express/Savana and Workhorse ETC pinouts.
What actually helps this thread
Post real identification evidence only: donor VIN + build date, PCM and TAC label photos (with connector colours), pedal and throttle part numbers, clear connector-face photos, continuity results, factory-document references, and scan-tool OS/calibration IDs. Please don’t post guesses or copied internet pinouts as corrections — factory-document captures and VIN-backed data are how we tighten this up.
Full article with complete tables, diagrams and the source list: GM 8.1L Vortec L18 Drive-by-Wire Wiring: 2001–2002 vs. 2003–2006 - FullSizeChevy.com
