2002 Avalanche 2500 8.1L
This is my 2002 Avalanche 2500. 8.1 Vortec, 4L80E.
I got it with fairly low mileage (196,000KM) after it had been sitting for a year.
It kept getting broken into - theives had gutted the cats, punched the ignition cylinder out, stole the stereo out of it, etc. Thankfully they left the power wires though!
I was able to get a screwdriver in the ignition and hear it FIRE - but not run. The Security light was active as there was no key; so it would just shut down after it fired. I bought it after a few starts and able to verify it had good oil pressure. Once I verified the oil pressure was good, we hauled it onto my flatdeck with the Warn PullzAll 120V winch and took it home.
The goal was (and still is) to just use it as a tow rig when needed, and to replace my Duramax which I had sold during Covid.
The first order of business was getting it running. A new ignition and lock cylinder was ordered and installed, as well as a driver’s door handle.
Here is what it looked like when I first got it.
I really liked the interior colors.
The next step after getting it running involved basic maintenance, a new exhaust (magnaflow 12590 + black tip), and some newer 8 bolt GM 20’s to go on it.
I should have kept the PY0’s but the lip was not good on them.
Here was the first day it came back from the exhaust shop!!!
After it was running, I decided that I wanted to lift it a touch. After doing some research, I went with the 3" Zone kit PN ZONC31. This was the only lift that had a front differential drop bracket, that claimed to keep close to stock geometry.
While we were at it I threw the same year suburban 2500 springs in as the one side spring was broken. The springs added a leaf, some rear lift and an extra 250 lb payload per side.
I was still deciding on wheels at this point; but eventually just decided to go with newer 8 bolt Gm wheels and have them powdercoated black to match. They are LTZ/Denali factory take-offs (had a 2015 with them and liked them).
I had to get wheel adapters that were hub/lug centric. They were not cheap but I wanted to make sure that I spent the money as I planned on using it to tow here and there. I believe the wheel adapters came from uswheeladapter.com and it took a little bit for them to get to me.
This was the first rendition of the 2500 fresh out the tire shop; just with 275s to fit. While we were at it, we also did all new brakes. I had to trim the front bumper a touch but other than that all the big stuff is done.
The suburban springs helped a ton in the back, as the back end hardly moves when you jump on it or hook a trailer up to it.
The next order of business was some small details: black headlights, fogs/taillights, interior LEDs and newer style towing mirrors. I went with the Sealight 9005/9006 bulbs as I have had good luck with them in the past and they are supposed to last 7 years.
I did also use CERAKOTE Trim restorer on the cladding. It seems to last about a year. I initially thought I would paint the cladding, but for now I am keeping it as I like the black/grey look.
I went with the 16+ tow mirrors (Amazon specials) with the black smoke running LED, however they are still not wired up. Most likely will grab power for the mirror lights from the underhood fuse block for trailer lights, or I may tap into the BCM. I plan on doing the mirror wiring once I do the speakers.
After this I was onto maintenance and other items at this point. The existing K&N was kept (which was installed by the previous owner) - but I used a dry filter to avoid the MAF plugging up. The filter part number is K&N RU-3101HBK. I did a tuneup as well, which included a bottle of seafoam in the gas, new fuel filter (which was a PITA had to use crowsfeet to change it) and finally New delco iridums gapped at @ 0.045. I used NGK wires as well, and would recommend doing wires when doing plugs.
I truthfully think if you own an 8.1 Vortec you need to do plugs and wires each year, as they are known to eat plugs.
I then proceeded to do the hitch upgrade. You can read more on that here.
It cleaned up pretty good!
I then started on building a “drawer/slider” combo for the box. I really wanted a drawer + slider combo for some tool/belt/part storage etc.
This slider/drawer combo actually worked out pretty good! I built it using puckboard and treated plywood with 2x2s and stained it black. I also added kickback mudflaps as well around this time. I was planning on using the truck for camping here and there as well, so it was good to knock this drawer/slider off.
The last step was the black “plastic checkerplate” that I found at a local Princess Auto. I was able to glue it down and silicone the edges so that the plywood underneath would not get wet.
The next upgrade I did was the cluster upgrade. I upgraded to the 2002 Escalade cluster - which in my humble opinion is the nicest GMT800 Cluster. I went with Ice Blue LEDS!
Mileage had to be swapped so inevitably the stock cluster went with the cluster guy but I prefer the escalade cluster all day (my 98 has an escalade cluster, they are good upgrades)
I REALLY like the look of the cluster with the ice blues in there.
I did Timbrens for the rear end right around this time as well for a simple towing upgrade. I did NOT want to have to deal with air bags or an air compressor.
GMRSB4S was the part number, says its good for 3600 lbs. The driver’s side was NOT Fun to get in there. The factory brake lines are very close to where you need to remove the old bump stop and put the new Timbren in. Once that was done, I hooked it onto a trailer to test it out and they did great!
I was having issues with the tailgate falling down while driving (latch issues!!) so I then rebuilt the tailgate. More on that in the video below.
I grabbed an EDGE CTS3 for insights - and realtime monitoring. I found the Edge mount locally, but if you’d like to check the complete kit out here is a link. I got it dialled in pretty good to the Ice Blue color using a custom hex color code. I painted the Edge dash mount using SEM Paint.
I added the DNA Motoring Double Din Bezel, and swapped to a Kenwood DMX709S Double Din as well. If you want to see how that happened, head over to the 99-02 Double Din Installation Guide.
Stereo FINALLY happened this spring. I realistically just said enough was enough. I had thought about hiring that out last year, but after being quoted close to 7K for a stereo I decided I would just pick away at it and do it myself. I still have to clean up the wiring a touch and change the speakers out, but I used the wiring from the previous owner and put in an JL 400/4 amp for the speakers.
If you have an Avalanche or Escalade EXT and want to add subs you can be limited for choices of boxes. I had thought about cutting the midgate, but didn’t want to ruin the integrity of my midgate. After some research I went with the Audison Powered subwooder with a built in amp. It was basically 4.7” tall and it was between it or the JL version. I am actually really happy with my choice, as the midgate is still functional and the sub does put out a good amount of bass! It was simple to hook up as well, power and remote, and saved me needing to buy another amp.
I did the Boost Auto Wireless charger as well, which I found to be very helpful for roadtrips. It matches pretty good too!
One of the last items I did to the 8.1L recently was the installation of a ram air hood.
It took a bit to find honestly, but surprisingly found it in a junkyard on a wrecked Avy.
I believe this to be the old model Keystone GHG-120 as it has the functional ram air. The scoops are functional, the underside is sealed, and the air goes directly into the scoops and is then channeled to the airbox). I was worried about water intrusion - and had thought about using the same hood fitting that the L5P uses. I had a L5P but had terrible luck with it staying out of the dealership for service (I had one before but got rid of it during Covid). Luckily it has weep holes already to drain off any moisture.
I definitely am really happy with how the front end turned out!
Future plans for this rig will likely include seat reclamation and some interior paint touchups. The driver’s seat is needing some repair- and I have some small paint chips on the dash. Nothing too crazy, but figure I might as well do those next.
I bought the 2500 in 2022, just before the 8.1/496 started getting the attention it deserves on social media. There is not a ton of aftermarket support for the 8.1, but it is getting better. Companies like Raylar have been around for a long time; but the price tag is just a bit too high in my opinion.
For performance, I would absolutely LOVE to cam it and throw either a stage 1 or a stage 2 in it. I am keeping an eye on Richard Holdener Performance to see when he announces the stage 2 cam. The RHP/Elgin Stage 1 8.1L cam offers 25-30 hp and 25-30 lb-ft of torque gains over the stock 8.1L cam, while maintaining a near stock idle quality.
I’m not sure if I am crazy about the near stock idle quality. Let’s be honest; if I am going to cam it I would want to actually hear it! I plan on doing the 8.8 top end upgrade and trying to get it around the 500 hp/ 600 tq torque mark.
Anyways, that is my plans for the 8.1!
Took the big block Avalanche out tonight to stretch its legs and burn some gas (6 gallons, to be exact).
Nice to see the ram air hood doing exactly what it was built to do.
Ambient air: 11°C (52°F) (also verified via thermometer)
Intake Air Temp (IAT): 17°C (64°F)
That’s only a 6°C (11°F) increase over ambient, which is pretty impressive for an 8.1L. These big blocks sure put out underhood heat.
Glad to see the intake is getting plenty of cool outside air instead of sucking in hot underhood air!
