You’re not finding true “new” sawblades anymore. Everything is either refurbished OEM or used.
Best Options
1. Refurbished OEM (easy route)
Vendors like Original Wheels carry refinished sets. The link to the Original Wheels sawblades is here.
Ebay also lists some variants of refinished wheels, link here.
Clean, ready to bolt on. Double check that center caps are provided, as often times vendors do not provide the center caps.
More expensive option than cleaning your factory ones up.
Still OEM cores, just refinished (you can do this yourself too)
2. Used Sets (best value)
Facebook Marketplace, forums, junkyards
~$200–$800 per set, depending on condition
Expect oxidation, peeling clear, curb rash
Ideal if you plan to restore them.
3. Reproductions
Available but not true OEM
Lower resale, not preferred by most OBS guy
Center Caps (Big Pain Point)
If you’re piecing together a set, center caps are usually the hardest part to find in good shape.
OEM Caps
GM Part #: 15650047
Smooth brushed aluminum finish
No logo
Push-on style
Most originals are worn, faded, or missing
NOTE: The NBS Escalade center caps are similar, however feature the escalade logo.
Aftermarket Option
Still in production
Fitment is solid, clips in properly
Finish isn’t perfect vs OEM, but close enough
One of the few Dorman parts that’s actually acceptable
What to Check Before Buying
Deep pitting (avoid it)
Lip damage / curb rash
Matching set of 4
Center caps included
Correct specs (16x7, 6x5.5)
Bottom Line
Want easy → buy refurbished
Want cheap → buy used and restore
Sawblades are getting harder to find. Clean sets don’t last.
