Which GMT800 engine did you end up with — 4.8, 5.3, 6.0, or 8.1?
Everyone’s got an opinion on the GMT800 engines, so let’s hear the real-world takes instead of the same recycled wisdom.
The quick version from our GMT800 engine guide: the 5.3 (LM7) is the do-everything sweet spot, the 6.0 (LQ4/LQ9) is the tow-and-build king, the 4.8 (LR4) is the underrated budget workhorse, and the 8.1 (L18) big-block is for serious hauling.
But spec sheets aren’t the same as living with one. So:
  • Which engine is in your truck, and what year/model?
  • What do you actually use it for — daily, towing, work, or a build?
  • Mileage now, and what’s failed (or held up)?
  • If you were buying again tomorrow, same engine or different?
Post your combo below. The goal is to help the next person figure out which one to hunt for.
4.8L in my '04 Tahoe
So far just regular daily driving but I’ll be towing a relatively light aluminum boat with it as soon as the low temps drop under 80 in the mornings. :hot_face:
148k and according to the extensive service records from the municipality that had it before me and owned it since new nothing was done to the engine/transmission other than tune ups and fluid changes.
I’d love a 6.0L of course but plenty happy with my 4.8!
I’ve had reallly good luck in the past with the 5.3 LM7 and the 6.0 LQ4, both are bulletproof engines IMO. I think to date I have had 4 or 5 5.3’ trucks and 1 6.0 LQ4 in an AWD Yukon Denali and all ran super well.
Knock sensors on the earlier 5.3’s was my only complaint, as on a few trucks in the past I had to pull the intake to get at the knock sensors. Not a big job, but also not super fun. Glad on the later Gen4’s they swapped knock sensors to side of the blocks!
I currently daily a Gen 5 5.3 K2XX, with a gen 4 5.3 900 as a backup. I had a K2XX 6.0 gas and loved it, traded it in for first year L5P Duramax which was a terrible idea. That first year L5P Duramax was a beautiful truck, but it was poorly made and spent most of its life at the dealer being repaired (thank goodness for warranty!)
If I need to tow anything I’ll take the L18 8.1L +4L85E combo, which is HPTuned, has intake/exhaust and Timbrens in the rear. To date I have hauled 13,000 LB with it successfully. I would rather have an old big block anyday over a new diesel with payments!
