The Rochester Quadrajet is a capable carb that gets a bad reputation mostly from worn-out, neglected units. On 1973–1987 Squarebody trucks with 305 or 350 engines, most Q-jet problems come from age and failed rebuilds — not design flaws.
SYMPTOMS
- Stumble on acceleration from idle
- Hard hot start or vapor lock behavior
- Rough idle that changes with temperature
- Black smoke or strong fuel smell
- Fuel overflow from the vent tube
CAUSES
- Worn throttle shaft bushings — air leaks kill idle quality
- Cracked or warped float — float sinks and floods the engine
- Varnish buildup from old fuel clogging idle circuits
- Previous rebuild with wrong jet sizing
- Bad needle and seat — floods or starves the bowl
FIX
- If throttle shaft has more than 0.010" play — rebuild or replace the carb body
- Rebuild with a quality kit from Grose Jet or Carb Parts Warehouse
- Set float level to factory spec — critical for correct fuel height
- Adjust idle mixture screws properly: screw in until idle drops, then back out 1–1.5 turns
- Use a vacuum gauge for idle mixture tuning — don’t guess
- Check accelerator pump for cracks before assuming jetting is the problem
TUNING TIPS
- Primary jets handle most street driving — don’t go more than 2 sizes in either direction
- Secondary air valve spring tension affects WOT feel — lighter spring = more aggressive secondary opening
- Choke pull-off must work properly — sticking causes flooding on cold start
REBUILD INTERVAL
- Rebuild every 5–7 years on a driver
COMMON MISTAKES
- Rebuilding a carb with a damaged throttle shaft — wastes money
- Adjusting the idle mixture with the choke open and engine cold
- Using a cheap rebuild kit with incorrect floats
CHEAP VS PROPER FIX
- Cheap: shoot carb cleaner in and adjust screws — temporary at best
- Proper: full rebuild with quality kit or a known-good reman unit
Recommended Parts
- LicBund 1406 Carburetor Replacement for Edelbrock Performer 600 CFM: Amazon.com: LicBund 1406 Carburetor Replacement for Edelbrock Carburetor Performer 600 CFM : Automotive
- Rochester Quadrajet Carburetor Rebuild Kit for 1972-1978 Chevy Trucks: Amazon.com
