The Gen V 5.3L EcoTec3 in the 2019+ T1XX Silverado/Sierra is a tuner-friendly engine. Here’s a breakdown of all the tuning options available.
Why Tune the T1XX 5.3?
- Increase HP and torque output
- Disable DFM (Dynamic Fuel Management) cylinder deactivation
- Optimize shift points on the 10-speed
- Improve throttle response
- Customize towing/trailer mode behavior
Option 1: DiabloSport inTune i3 (Best Beginner Option)
Plug-in handheld device. Pre-loaded tunes for common mod combinations. No custom tuning needed. Works on stock or modded trucks.
Option 2: HPTuners VCM Suite
HPT MPVI4 Interface (HP Tuners) – The professional-grade tuning platform. Requires credits per tune but provides complete access to every parameter in the ECM/TCM.
Option 3: Bama Custom Tune
Available through several online tune shops. You provide your mod list, they create a custom .bin file that you flash with their handheld device.
What a Tune Can Do on T1XX 5.3:
- DFM disable: Keep all 8 cylinders active (requires tune or Range Tech device)
- Power: +25–50 HP/torque on a stock truck
- With intake + exhaust + tune: +50–80 HP
- 10-speed calibration: Improve shift feel and prevent gear hunting
- Remove speed limiter (optional)
Important: Gen V Tuning Complexity
The Gen V EcoTec3 has more complex emissions calibrations than Gen III/IV. Ensure your tuner has Gen V experience.
DFM Delete Without Tune:
Range Technology RA003B AFM/DFM Disabler – Plug-and-play DFM disable without any flashing. The easiest way to prevent DFM cycling without a tune.
What tune are you running on your T1XX 5.3?
