Towing Capacity K2XX 2500HD 6.6 Duramax – Real Numbers
The 2014–2018 Silverado/Sierra 2500HD with the 6.6L L5P (or LML) Duramax diesel is a serious tow vehicle. Here’s the complete towing capacity breakdown.
Official Towing Ratings (2500HD Duramax, K2XX):
Configuration Conventional 5th Wheel
2WD Regular Cab 17,900 lbs 18,100 lbs
4WD Crew Cab Short Box 14,800 lbs 16,200 lbs
What’s Required to Achieve Maximum:
  • Proper hitch receiver (factory 2" or gooseneck prep package)
  • Trailer brakes operational
  • Correct axle ratio (3.73 or 4.10)
  • GCWR not exceeded
The Allison 1000 Transmission:
The K2XX 2500HD Duramax uses the Allison 1000 6-speed automatic. This is one of the best transmissions ever paired with a diesel engine – extremely durable and capable.
Towing Best Practices:
  1. Monitor transmission temp (stay under 220°F sustained)
  2. Use exhaust brake for long descents
  3. Maintain EGT (exhaust gas temp) under 1400°F continuous
  4. Weight distribution hitch for large conventional trailers
  5. Pre-trip inspection of all trailer connections
Brake Controller:
For trailers with electric brakes, a properly calibrated controller is essential.
Proportional Brake Controller – Works with the factory 7-pin connector on K2XX trucks.
Common Issues When Towing Heavy:
  • High transmission temps without external cooler
  • DEF system issues at high mileage
  • Fuel dilution in oil on LML engines (CP4 pump failure)
What are you towing with your K2XX 2500HD Duramax? Share your rig!
