The 2007–2013 Silverado/Sierra 2500HD with the 6.6L Duramax diesel is one of the most capable tow rigs from this era. Here’s a complete breakdown of towing capacity, ratings, and real-world tips.
Official Towing Capacities (2500HD LMM/LML Duramax):
| Configuration | Max Tow Rating |
| 2WD Regular Cab, Long Box | 17,000 lbs (conventional) |
| 4WD Crew Cab, Short Box | 14,500 lbs |
| 5th Wheel/Gooseneck | 18,000 lbs |
What Affects Your Actual Capacity:
- GVWR (Gross Vehicle Weight Rating) – shown on door placard
- GCWR (Gross Combined Weight Rating) – truck + trailer max
- GAWR – Gross Axle Weight Ratings front and rear
- Hitch receiver rating (standard 2-inch vs factory gooseneck prep)
Real World Towing with the LMM/LML:
The Duramax 6.6L with the Allison 1000 transmission is an excellent long-distance tow rig. Most owners comfortably tow 12,000–15,000 lbs and report excellent transmission temperatures with proper setup.
Towing Tips:
- Use a weight distribution hitch for trailers over 5,000 lbs tongue weight
- Monitor transmission temps – Allison should stay under 250°F
- Install a transmission temp gauge if towing regularly
- Consider a lift pump upgrade (FASS or AirDog) for sustained high-load towing
- Ensure trailer brakes are properly adjusted and calibrated
Brake Controller:
For trailers with electric brakes, you need a properly calibrated brake controller. Proportional Trailer Brake Controller – Plugs into your factory 7-pin connector for the best brake feel.
Maximum Payload:
Don’t forget payload ratings. Even if your truck can tow 16,000 lbs, your payload rating (typically 2,000–3,000 lbs on a 2500HD) limits how much tongue weight you can put in the bed.
Key Towing Mods:
- Transmission cooler upgrade
- Exhaust brake (banks or similar)
- EGT gauge monitoring
- Airbag assist (if towing heavy 5th wheels)
What are you towing with your GMT900 Duramax? Share your setup and tips below!
