Towing Capacity GMT800 2500HD 6.0 – Real Numbers
The 1999–2006 Silverado/Sierra 2500HD with the 6.0L Vortec is one of the most capable factory gas tow rigs from this era. Here’s what it can actually handle.
Factory Tow Ratings (2500HD 6.0L LQ4):
Config Conv. Tow 5th Wheel/Gooseneck
2WD Regular Cab, 8’ Box 12,000 lbs 16,000 lbs
4WD Crew Cab, 6.5’ Box 11,200 lbs 15,000 lbs
Always Verify With Your Door Placard:
These are nominal numbers. Your specific truck may be rated differently based on options, axle ratio, and GCWR.
The 4L80E Advantage:
The 2500HD 6.0L comes with the 4L80E heavy-duty automatic, which is rated for significantly more torque than the 4L60E in 1500s. This is why the 2500HD can tow so much more.
Real World Towing Tips:
  1. Monitor trans temp: Even with the 4L80E, install an external transmission cooler for sustained towing
  2. Proper axle ratio: The 3.73 ratio is standard, 4.10 is ideal for towing
  3. Weight distribution hitch: For trailers over 5,000 lbs tongue weight
  4. Brake controller: For trailer electric brakes
Transmission Temperature:
The 4L80E should stay under 220°F sustained. Over 250°F = stop and cool down.
Mishimoto Transmission Cooler – One of the best upgrades for any towing 2500HD.
Payload Reminder:
The 2500HD payload (typically 2,500–3,500 lbs) limits how much tongue weight you can put in the bed. Don’t forget this when calculating your total load.
What are you towing with your GMT800 2500HD 6.0? Share your setup!
