The 1988–1998 GMT400 Silverado/Sierra 2500 with the 5.7L TBI or Vortec engine is a capable tow rig, but what are the real-world numbers? Here’s the full breakdown.
Official Factory Towing Ratings (2500 Series, 5.7L):
| Configuration | Max Tow (Conventional) |
| 2WD Regular Cab, Long Box | 9,700 lbs |
| 4WD Crew Cab | 8,000 lbs |
| 5th Wheel Equipped | 12,000 lbs |
What Affects Your Actual Capacity:
- GVWR on door placard
- 4L60E vs 4L80E transmission (HD package)
- Axle ratio (3.73 vs 4.10 makes a difference)
- Tow/haul mode availability (late model trucks)
Real World with a 5.7L:
The TBI 5.7L is rated for about 210 HP and 300 ft-lbs of torque. In a 2500, it can comfortably handle:
- 8,000–10,000 lb trailer with proper gearing
- Transmission temps need monitoring over 8,000 lbs
Transmission Cooling is Critical:
When towing regularly with the 5.7L and 4L60E, add a transmission cooler. The factory cooler inside the radiator isn’t sufficient for sustained heavy towing.
Mishimoto Transmission Cooler – Excellent auxiliary cooler that significantly reduces transmission temperature under load.
Best Axle Ratio for Towing:
The 4.10 rear axle ratio (available on 2500/3500 HD packages) is the preferred ratio for towing with the 5.7L. The 3.73 works but the engine works harder.
Practical Tips:
- Never exceed GCWR (truck + trailer combined weight)
- Weight distribution hitch for trailers over 5,000 lbs tongue weight
- Trailer brakes required for trailers over most state limits (usually 3,000 lbs)
What are you towing with your GMT400 2500? Share your rig and setup!
