T1XX Silverado 1500 Max Tow Package – What's Included?
The 2019+ Silverado/Sierra 1500 Max Trailering Package significantly increases towing capacity. Here’s what’s in the package and what it does.
Standard vs Max Tow Capacity:
Without Max Tow Package: Up to ~11,000 lbs (with 5.3L)
With Max Tow Package: Up to 13,400 lbs (5.3L) or 13,300 lbs (6.2L with 10-speed)
What’s Included in Max Tow Package:
  1. 3.42 rear axle ratio (vs standard 3.23) – better low-speed towing leverage
  2. Additional transmission cooler – extended-capacity external cooler
  3. Larger brake system – improved stopping power with trailer
  4. Hitch guidance camera – camera assist for hitching in cab display
  5. 7-pin trailer connector (if not standard)
  6. Integrated Trailer Brake Control (on applicable trims)
The Axle Ratio Impact:
The 3.42 axle ratio vs 3.23 provides noticeably better towing performance, especially on grades. The trade-off is slightly lower highway fuel economy (about 0.5–1 MPG).
Adding a Trailer Hitch (If Not Equipped):
Draw-Tite 41553 Class IV 2" Receiver Hitch – Silverado/Sierra 1500 2019–2026 – Dealer-quality hitch that fits T1XX 1500s for those adding aftermarket towing capability.
Do You Need the Max Tow Package?
If you tow over 10,000 lbs regularly, yes – the extra trans cooler and axle ratio make a real difference. For lighter towing (under 8,000 lbs), the standard package is sufficient.
What tow package did your T1XX come with? What are you towing?
