Overview of Swapping a 4.3 V6 to a V8
This thread addresses the common question of swapping a 4.3 V6 engine in a 2001 Silverado with a V8, specifically focusing on LS1 and 4.8/5.3 engines. The discussion covers various components and considerations necessary for the swap.
Details on LS1 and 4.8/5.3 Swaps
LS1 Swap
- Wiring Harness: A new wiring harness is required for an LS1 swap. If using LS1 accessories, a custom wiring harness is preferred due to the location of the alternator and injector plug.
- PCM: The 4.3 PCM can be reflashed, or a used PCM and wiring harness can be purchased for around $300.
- Belt Accessories: If using 5.7 LS1 bracketry and intake, all new belt accessories are needed. If using 4.8/5.3 bracketry and intake, not all new belt accessories are required.
- Fuel Pump: The original fuel pump is compatible.
- Driveshaft: No modifications are necessary.
- Intake System: An aftermarket intake system is required.
- Transmission: The stock transmission will work, but a shift kit is recommended.
- Engine Mounts: New 4.8/5.3 engine mounts are required.
- Exhaust System: A new exhaust system is needed.
4.8/5.3 Swap
- Wiring Harness: A stock wiring harness from a 4.8/5.3 will work and is priced around $400.
- Belt Accessories: Not all new belt accessories are required.
- Intake System: A 4.8/5.3 intake system is required.
- Transmission: The stock transmission will work.
Components Needed for the Swap
- Complete engine
- Belt accessories and brackets
- 4.8/5.3 engine mounts
- Wiring harness (custom for LS1 with 5.7 accessories)
- New exhaust system
- New PCM or reflashed 4.3 PCM
- Intake system (aftermarket for LS1, 4.8/5.3 for 4.8/5.3)
Community Responses and Clarifications
- Tranny Compatibility: The stock transmission will work with a 4.8/5.3 or LS1, but a shift kit is recommended.
- Fuel Lines: The 4.3 has hard fuel lines, while the LS1 has flexible lines.
- Registers: New motor mounts and registers are required for the swap.
- AC Compressor: Conflicting information exists regarding the compatibility of the 4.3 AC compressor with LS1 brackets.
Community Feedback
- User Support: Users provided valuable insights and confirmed the accuracy of the information.
- Helpful Resources: Users suggested contacting specific vendors for detailed guidance and parts.
Future Plans
- The user plans to complete the swap and update the thread with further details.
