Squarebody Overheating Fix: 350 and 454 Cooling System Guide (1973–1987)
Running hot on a Squarebody is common. The factory cooling system on 1973–1987 C10, K10, and Suburban trucks was marginal from the factory — especially with a 350 or 454 under the hood.
SYMPTOMS
  • Temp gauge climbing past the halfway mark at idle or in traffic
  • Coolant overflow after shutdown
  • Steam from under the hood
  • Heater blowing cool air while engine runs hot
CAUSES
  • Stock 2-row aluminum radiator inadequate for modified engines
  • Water pump impeller erosion on high-mileage pumps
  • Thermostat stuck partially closed
  • Air pockets in system after improper fill procedure
  • Collapsed lower radiator hose under suction
  • Clogged radiator from 40+ years of scale buildup
FIX
  • Replace with a 3-row or 4-row brass/copper core radiator
  • Install a new 160°F or 180°F thermostat depending on climate
  • Replace water pump — AC Delco or Melling are reliable choices
  • Flush system with a quality flush kit before filling
  • Use a 50/50 mix of Dex-Cool or green coolant depending on year
  • Check lower hose for softness — replace if it collapses under squeeze
  • Add a coolant overflow tank if not already present
PREVENTION
  • Flush coolant every 2 years regardless of mileage
  • Inspect belts and hoses annually
  • Run a quality thermostat — cheap thermostats fail partially open or closed
  • If you have a 454 or built 350, upgrade the fan clutch or go electric
COMMON MISTAKES
  • Skipping the air bleed procedure after refill
  • Running without a thermostat — this kills flow velocity
  • Buying a cheap eBay radiator that fails within a season
  • Ignoring a soft lower hose until it collapses and cavitates the pump
CHEAP VS PROPER FIX
  • Cheap: new thermostat and flush — buys time but not a permanent solution
  • Proper: 3-row radiator + new water pump + belt and hose refresh
Recommended Parts
  • ALLOYWORKS 3-Row Aluminum Radiator for 1973-1991 Chevy C10/K10: Amazon.com
  • ADIGARAUTO Water Pump for GM 4.3L/5.0L/5.7L Engines: Amazon.com
  • Edelbrock 8604 180°F High Flow Thermostat: Amazon.com
