Square Body Wiring Nightmare – Full Harness Replacement Guide
The factory wiring on 1973–1987 C/K trucks is now 35–50 years old. Brittle insulation, mouse damage, and decades of DIY splices can make the factory harness a nightmare. Here’s when to repair vs replace.
Signs You Need a New Harness:
  • Multiple electrical gremlins with no clear source
  • Lights flickering, random fuse blows
  • Evidence of rodent damage (chewed wires, nesting)
  • Previous owner did extensive undocumented wiring
  • Restoration project where originality isn’t a concern
Option 1: Factory-Style Replacement Harness
Several companies make reproduction wiring harnesses for the 73–87 trucks that match the factory layout. These are the best choice for a restoration.
Option 2: Universal Street Rod Harness
For modified or restomod builds, a universal street rod harness (Ron Francis, Painless Performance) gives you a clean, modern-rated harness with circuit breakers instead of fuses. Great for LS-swapped builds.
Painless Performance 60508 LS1 Standalone Harness – For LS-powered builds, this handles all engine management wiring cleanly.
Option 3: Partial Harness Replacement
Replace only the most damaged sections and repair the rest. Works when the overall harness is in decent shape.
Full Harness Replacement Steps:
  1. Photograph everything before removal – document every connector
  2. Label each wire circuit before removal
  3. Install new harness one circuit at a time
  4. Test each circuit before moving on
  5. Clean and protect all connections with dielectric grease
Important: Ground Strap Network
The most common cause of weird electrical issues on old trucks is poor grounds. Before replacing the harness, check/replace:
  • Battery negative to block
  • Block to firewall
  • Firewall to body
  • Body to frame (multiple points)
Cost:
  • Reproduction harness (engine + body): $500–$1,200
  • Universal street rod harness: $400–$800
  • Professional installation: $800–$2,000
What wiring work have you done on your Square Body?
