Square Body Front Axle Upgrade – Dana 44 vs 60
If you’re building a serious off-road K10, the front axle is a critical decision. The factory Dana 44 can handle most builds, but there are good reasons to upgrade to a Dana 60. Here’s the breakdown.
Factory Axle by Model:
  • K10 (1/2 ton) 1973–1987: Dana 44 front, Dana 44 rear
  • K20 (3/4 ton) 1973–1987: Dana 44 front, Dana 60 rear (some models)
  • K30 (1 ton) 1973–1987: Dana 60 front, Dana 60 rear
Dana 44 Strengths:
  • Adequate for most off-road use with 35" tires
  • Easier to find parts for
  • Lighter weight
  • Most common swap donor axle
Dana 44 Weaknesses:
  • Weaker ring and pinion under high torque
  • U-joint knuckles more susceptible to failure with big tires
  • Not ideal for 37"+ tires and high-power engines
Dana 60 Strengths:
  • Much stronger ring and pinion (10.5" ring gear)
  • Tougher knuckles
  • Handles 37"–40" tires with ease
  • Better for locking diff applications
Dana 60 Sources:
  • Junkyard trucks (K30 pickups, heavy trucks)
  • Ford F-350 Dana 60 (high pinion, preferred for clearance)
  • Aftermarket aftermarket Dana 60 (most expensive but new)
High Pinion vs Low Pinion:
The factory GM Dana 60 is a low-pinion axle (pinion below the centerline). The Ford Dana 60 is high-pinion (better ground clearance, stronger shaft angle). For serious builds, most people prefer the high-pinion Dana 60.
Cost Comparison:
  • Dana 44 rebuild/regear: $500–$1,500
  • Used Dana 60 sourced from junkyard: $300–$800 before rebuild
  • New aftermarket Dana 60: $2,000–$4,000
What axle setup are you running under your K10? Dana 44 or have you made the jump to the 60?
