Rust Repair on Classic Chevy Trucks: Where to Start & What to Expect
Rust is the number one enemy of classic Chevy trucks. Whether you’re dealing with surface rust on the cab corners, rotted floor pans, or swiss-cheese rocker panels, this guide covers how to tackle it step by step.
Step 1: Assess the Damage
Before you buy materials or start cutting, figure out exactly how bad it is.
  • Surface rust — Pitting in the metal surface, no holes, still structurally sound
  • Scale rust — Thicker buildup, surface is compromised but metal is still there
  • Penetrating rust — Holes or crumbling metal, needs replacement panels
Use a screwdriver or pick to probe suspect areas. If it pokes through, you’re replacing, not treating.
Most-affected areas on 1947–1972 C10:
  • Cab corners (lower rear of cab)
  • Floor pans (especially driver’s side)
  • Rocker panels
  • Bed floor and bed rails
  • Firewall
  • Door bottoms
Step 2: Surface Rust & Light Scale Rust
If the metal is solid, you can treat it:
  1. Remove loose rust with a wire wheel or flap disc on an angle grinder
  2. Apply rust converter to neutralize active rust chemically
  3. Apply a rust-encapsulating paint like Chassis Saver over the treated surface — bonds to bare metal and stops rust from reforming
  4. Topcoat with primer and paint as needed
Step 3: Patch Panels & Floor Replacement
For holes or heavily rotted sections, cutting and welding is the only real fix.
Tools needed:
  • MIG welder (or find a local shop)
  • Angle grinder with cut-off wheel
  • Body hammer and dolly set
  • Clamps and magnets for panel alignment
Floor pans: Replacement floor pans for 1967–1972 C10 are widely available. Cut out the old floor with a 1/2" margin, weld in the new pan, seam seal and undercoat.
Cab corners: Buy reproduction cab corners from Classic Industries or AMD. Cut the old corner off at the factory seam, weld in the new piece, grind smooth.
Step 4: Prevent Future Rust
After repairs:
  • Apply seam sealer to all welds and joints
  • Coat the underside with rubberized undercoating or chassis paint
  • Use wax-based cavity spray in door cavities and rocker panels
  • Keep it dry — even one puddle under a mat can restart rust in months
Products That Work
The key with classic Chevy rust repair is catching it early and treating it permanently, not just cosmetically. Take your time with the prep work and the results will last.
