Recalls & knock noise: GM's 2000-2003 headache
Recalls & knock noise: GM’s 2000-2003 headache
Digging through this thread showed the recall notices and piston knock chatter that kept popping up back then.
Recall hits
  • 2000 Suburbans/Tahoes/Silverados/Sierra/Yukons/Yukon XLs were part of a 525,254-vehicle airbag SDM recall; dealers recalibrated the modules and GM told owners to call Chevy or GMC if they did not get the free remedy.
  • 2003 Yukon XL/Suburban/Avalanche were recalled for the fuel tank assembly and those models plus Escalade and Tahoe also had door hinge/body recalls.
Why folks care
The March/April '03 TruckTrend write-up says the cold-start piston knock on the '99-'02 4.8/5.3/6.0 engines shows up after about 12,000 miles when carbon piles up above the top ring, GM claims no damage, but owners are told to have the dealer call the zone rep and many of the complaints have been resolved with warranty extensions or parts swaps.
One 2001 Sierra 5.3 owner had a connecting rod tear his block once the dealer agreed to a cold start and after the replacement motor started knocking too, so he raised it with customer service.
GM service bulletins apparently call the 90-second start-up knock normal, so dealers leave it alone.
Salesmen on cool mornings hear snap-snap-snap and say it sounds like a typewriter in a kettle drum, which scares people off before they even buy.
Dealer/GM stance
Some folks accuse GM of waiting out warranties, so they are forwarding the thread to machinists before even calling customer service.
Others report that calling GM directly scored them a 6-year/100,000-mile extension on the motor when the knock kept coming back.
The service manager chimed in saying he has not seen an engine failure from the piston noise but there is a separate torn oil pump pickup O-ring bulletin that causes aerated oil.
Owner fixes
He recommends removing the plugs, pouring Top Engine Clean into each cylinder, letting it sit overnight, turning the engine over 180 degrees, repeating the dose and overnight wait, reinstalling the plugs, running it until it smokes, and changing the oil since the cleaner flushes back into the crankcase.
He also warns the carbon comes back but most dealers will de-carbon for free under warranty.
That bulletin mentioned updated pistons, the same ones now used on the 2003 models, and he says swapping his 6.0 to Diamond forged pistons stopped the knock.
A different poster says a $20 combustion chamber cleaner will yank the carbon off like it did on his Jeep V8.
AC headaches & other recalls
One post warned that the 2003 XL’s new owner did not know about the fuel and door recalls and was also fighting a major A/C issue.
Another post pointed to bulletin #01-01-39-004A, which installs an auxiliary fan for poor performance and says the cycling switch on the accumulator can fake the symptoms, and there are no A/C recalls for the 2003 XL.
A Silverado owner measured 45-50°F vents at highway speed but 70-75°F when parked, noted his bad low-pressure switch was already replaced, and wanted to know if the same bulletin covers his truck.
Community vibe
The tone swings between guys convinced GM is trying to wait out warranties and the ones passing the thread to machinists before hitting customer service.
Others point out that even a 5.3 with 225k knocks like dice on cold starts yet still runs strong and uses no oil.
The advice shared is to have the dealer contact the zone rep so the complaint has some paperwork before they accept the noise.
