A P0300 random misfire on the 5.3L LS engine in a 1999–2006 GMT800 truck is a frustrating diagnostic challenge. Here’s a systematic approach.
What P0300 Means:
Random multiple-cylinder misfire. The ECM can’t pinpoint which cylinder(s) are misfiring, or multiple cylinders are involved.
Most Common Causes on GMT800 5.3L:
1. Spider Injector Failure (Pre-2002 TBI/MPFI trucks):
Trucks with the Gen III injection system had a “spider injector” central injection unit. When the plastic internal components fail, fuel delivery becomes uneven. This is extremely common.
MPFI Spider Injector for Vortec GMT800 – Direct replacement for the factory spider injector.
2. AFM Lifter Failure (2005–2006 trucks with AFM):
The AFM system’s collapsing lifters can fail and cause misfires on AFM cylinders.
3. Ignition Coils:
Individual coil-on-plug (COP) ignition coils are used on the LS engine. A failing coil usually throws a specific cylinder code (P0301–P0308) but can sometimes appear as P0300.
4. Spark Plugs:
Worn or fouled plugs are always a diagnostic starting point. AC Delco Iridium or Platinum plugs are the recommended spec.
Diagnosis Steps:
- Pull all codes with scanner – look for P030X codes alongside P0300
- Swap two coils between cylinders – if the misfire follows the coil, replace it
- Check spark plugs (pull and inspect)
- For older models, inspect/replace spider injectors
- Run a compression test if the above don’t resolve it
What caused your P0300 on the GMT800 5.3? Share your fix!
