P0300 Misfire on 5.7 Vortec GMT400 – Common Causes
A P0300 random misfire code on a 1988–1998 GMT400 with the 5.7 TBI or Vortec engine is one of the most common diagnostic challenges. Here’s a systematic approach to finding and fixing the root cause.
What P0300 Means:
P0300 is a random/multiple cylinder misfire code. Unlike P0301–P0308 (which point to specific cylinders), P0300 indicates the ECM detected misfires across multiple cylinders or can’t identify which cylinder is misfiring.
Most Common Causes on the 5.7 TBI/Vortec:
1. Cap and Rotor (TBI Era – Most Likely)
The TBI 5.7 uses a traditional distributor cap and rotor. Carbon tracking inside the cap and burned rotor tips are extremely common on 100K+ mile trucks.
2. Spark Plugs:
Old or incorrect spark plugs cause misfires. Check the gap – 5.7 TBI spec is .035"–.045". Use OEM-specification AC Delco plugs or equivalent.
3. Spark Plug Wires:
Cracked insulation, burned boots, and weak wires cause random misfires. Test by running the engine in a dark garage – look for arcing.
4. Fuel Delivery (TBI-Specific):
Low fuel pressure from a weak in-tank pump causes misfires under load. Check fuel pressure: 10–13 PSI for TBI, 58 PSI for MPFI.
5. EGR Valve (Vortec-Specific):
A stuck-open EGR valve dilutes the mixture and causes rough idle/misfire. Disconnect and plug the EGR to test.
Diagnostic Approach:
  1. Check for specific cylinder codes (P0301–P0308) in addition to P0300
  2. Do a spark plug inspection (check color, gap, condition)
  3. Do a cap and rotor inspection
  4. Check fuel pressure with a gauge
  5. Check compression (low compression = larger issue)
Autel AL319 OBD2 Scanner – Read all codes including misfire counters on the GM OBDI/OBDII interface.
What caused your P0300 on the GMT400? Share your diagnosis path below.
