OBS Headlight Conversion: Sealed Beam → Composite (Replaceable Bulb)
Straightforward upgrade. Better light output, easier maintenance, cleaner look.
What You’re Switching From
Sealed Beam
Bulb + lens + reflector = one unit
Replace the whole thing when it burns out
Basic 2–3 prong plug
Composite
Separate bulb + housing
Uses modern bulbs (9005/9006, 9007, H4, etc.)
Better beam pattern if done right
Parts You Need
Composite headlight housings (left/right)
Mounting brackets/buckets (composite style)
Adjuster screws + springs
Retainers / clips / bezels
Bulbs (matched to housings)
Bulb sockets or pigtails (if plugs don’t match)
Adapter harness (recommended)
Optional but smart:
Relay harness (more voltage = brighter lights)
Dielectric grease
Heat shrink + proper connectors
Planning
Verify core support compatibility (most GM OBS trucks are easy swaps)
Use matching parts (grille + brackets + housings if needed)
Avoid junk housings — OEM-style > cheap aftermarket
Don’t jam LED/HID into halogen housings unless designed for it
Removal (Sealed Beam)
Disconnect battery
Remove grille and headlight bezels
Remove retaining ring
Pull sealed beam forward and unplug
Remove old buckets/brackets
Install (Composite)
Bolt in composite brackets
Install adjusters + springs
Mount housings
Ensure adjusters move freely
Wiring
Best Option: Adapter Harness
Plug factory connector → adapter → new bulbs
No cutting, no guessing
Custom Wiring (if needed)
Identify: ground / low beam / high beam
Match to new socket
Solder or crimp properly
Relay Harness (recommended)
Pulls power directly from battery
Reduces voltage drop
Saves your headlight switch
Final Assembly
Install bulbs (don’t touch glass)
Apply dielectric grease
Reinstall grille/bezels
Trim plastic if needed
Aim Your Lights (Don’t Skip)
25 ft from wall
Mark headlight height
Low beam cutoff slightly below that line
Even left/right pattern
Common Issues
One side out
- Bad bulb or ground
High/low not working
- Wiring mismatch
Dim lights
- Voltage drop → use relay harness
Bad beam pattern
- Cheap housings or bad aiming
GM OBS Notes (88–98 C/K)
Usually bolt-on if you grab matching brackets + grille
Many trucks share core support
Easiest conversion compared to Ford/Dodge
Quick Checklist
Housings
Brackets
Adjusters
Bulbs + sockets
Adapter harness
Tools + wiring supplies
Time to aim properly
Clean upgrade. Worth doing once, doing right.
