OBS GMT400 Lighting TechPack (1988–1998)
Complete Bulb Chart + LED Conversion Guide
Platform: 1988–1998 Chevy / GMC C/K, Tahoe, Yukon, Suburban
This is the consolidated FSC master lighting reference for OBS trucks.
Built for restoration, troubleshooting, and full LED conversion builds.
:one: OBS GENERATION BREAKDOWN (CRITICAL)
1988–1994 (Early OBS)
  • Sealed-beam headlights standard (H6054)
  • Early tail wiring carried over from squarebody era
  • 1988–1989 used 1157 / 1156 rear bulbs
  • Slightly weaker factory headlight output
  • Mixed interior bulb socket usage
  • LED conversion slightly more involved
1995–1998 (Late OBS – Updated Front Clip)
  • Composite headlights introduced (9005 / 9006)
  • Rear lighting fully standardized to 3157 / 3156
  • Improved marker + turn integration
  • Interior lighting standardized to 194 / T10
  • Easiest OBS years to convert to LED
Key Difference:
Rear lighting changed after ~1990 and is fully consistent 1995–1998.
:two: EXTERIOR LIGHTING TECHPACK
HEADLIGHT SYSTEM
Location 88–94 95–98
Sealed Beam H6054 H6054
High Beam (Composite) 9005 9005
Low Beam (Composite) 9006 9006
Fog Lights H3 H3
Notes:
  • Relay harness upgrade highly recommended before LED swap.
  • LED sealed beams are direct replacement.
  • Composite housings benefit massively from proper grounding.
FRONT LIGHTING
Function Bulb
Front Turn Signal 1157
Parking Light 1157
Front Side Marker 194 / T10
Cornering Lamps (if equipped) 3157
REAR LIGHTING
Early OBS (1988–1989)
  • Tail / Brake: 1157
  • Reverse: 1156
1990–1998 (Standardized)
Function Bulb
Tail / Brake / Turn 3157
Reverse 3156
License Plate 194
License plate bulbs unchanged across all OBS years.
CAB + MARKER LIGHTS
Location Bulb
Cab Roof Lights 194 / 168
Fender Markers 194
Rear Side Markers 194
Third Brake Light 912 / 921
Cargo Light 921
:three: INTERIOR LIGHTING TECHPACK
OBS interiors are largely standardized 1993+.
Location Bulb
Gauge Cluster T5 or 194
HVAC Controls T5
Ash Tray 194
Dome Light 211-2 (41mm Festoon)
Map Lights 194
Glove Box 194
Stepwell / Courtesy 194 or 211-2
:four: LED CONVERSION STRATEGY (OBS-SPECIFIC)
Mandatory Upgrades
  • Headlight relay harness
  • LED-compatible flasher relay (prevents hyperflash)
  • Ground refresh at radiator support + rear frame
  • Inspect factory headlight switch (common failure point)
Known OBS Issues
  • Factory headlight switch overheating
  • Weak grounds
  • Rear harness corrosion
  • Inconsistent polarity on some circuits
Recommended Order
  1. Ground refresh
  2. Relay harness install
  3. Exterior LED swap
  4. Interior LED conversion
:five: COMPLETE LED SHOPPING CHECKLIST
Front
  • 2× Headlights (H6054 or 9005/9006 pair)
  • 2× Front turn 1157
  • 2× Parking 1157
  • 2× Marker 194
Rear
  • 2× Tail/Brake (3157 or 1157 early trucks)
  • 2× Reverse (3156 / 1156)
  • 2× Plate lights 194
Interior
  • 5–10× 194
  • 1× Dome 211-2
  • Cluster T5 pack
:six: OBS LIGHTING UPGRADE TIERS (FSC STANDARD)
Stage 1 — Restoration
OEM halogen replacements only.
Stage 2 — Modern Driver
Full exterior + interior LED conversion.
Stage 3 — Full OBS Retrofit
  • LED housings
  • Switchback front signals
  • Smoked / clear lenses
  • Sequential tails
  • Relay harness + upgraded grounds
This TechPack will remain pinned in the GMT400 section.
If you find corrections, year-specific variations, or diesel differences, post them below so we can refine this into the definitive OBS lighting reference.
Related FSC article for the lighting TechPack: the new OBS / GMT400 4-Hi Mod guide covers the single-relay headlight mod that keeps the low beams lit on high beam so all four bulbs run together — including DRL handling for 1990+ Canadian and 1995+ US trucks.
Discussion / wiring results thread: OBS / GMT400 4-Hi Headlight Mod — Wiring Methods, Results and Troubleshooting
