Max Payload GMT900 1500 – What's Actually Safe?
Payload capacity is one of the most misunderstood specs on half-ton trucks. Here’s a real-world guide to how much you can safely put in your 2007–2013 Silverado/Sierra 1500.
Where to Find Your Actual Payload Rating:
Your truck’s specific payload rating is printed on the yellow sticker inside the driver’s door jamb. This number is unique to your specific truck (cab/bed/engine/option combinations affect it). It’s typically between 1,200 and 2,200 lbs for a 1500.
What Counts Toward Payload:
  • All passengers (use 150 lbs per person)
  • All cargo in the bed or cabin
  • Weight of any accessories (toolbox, camper shell, etc.)
  • Tongue weight of any trailer (10% of trailer weight with standard hitch)
Real-World Example:
  • Payload sticker: 1,800 lbs
  • Two passengers: 300 lbs
  • Toolbox + gear: 400 lbs
  • Trailer tongue weight (5,000 lb trailer): 500 lbs
  • Remaining payload margin: 600 lbs (you’re good)
Signs You’re Overloaded:
  • Rear sags significantly when loaded
  • Steering feels light (front wheels unloaded)
  • Long braking distances
  • Rough/bouncy ride at highway speeds
Payload Upgrade Options:
Adding helper springs or airbag assists doesn’t increase your rated payload – it only improves the ride and handling at or near capacity. Airbag kits can help level the truck under load.
The 1500 vs 2500 Decision:
If you regularly haul heavy loads (equipment, hay, building materials), a 2500HD is worth the investment. The 2500HD has a rated payload of 3,000–4,000 lbs, significantly more than the 1500.
Tire Load Ratings:
Make sure your tires are rated for the load. Check the max load per tire listed on the sidewall and ensure 4x that number exceeds your GVWR.
What’s your payload setup on your GMT900 1500? Drop your sticker weight and what you’re hauling below.
