LQ4 vs LQ9 – What's the Difference in a GMT800?
If you’re shopping for a GMT800 2500HD or doing an LS swap, you’ll encounter both the LQ4 and LQ9 designations. Here’s an accurate breakdown of the differences.
LQ4 – The Standard 6.0L:
  • 6.0L displacement
  • Iron block
  • Cast iron cylinder heads, cathedral port
  • Lower-compression dished pistons (~9.4:1)
  • ~300–325 HP stock (depending on year)
  • Used in: Silverado/Sierra 2500HD/3500HD, Suburban/Yukon XL 2500, Express/Savana vans, various commercial trucks
  • Common years: ~1999–2007
LQ9 – The High-Output 6.0L:
  • 6.0L displacement
  • Iron block (same block family as the LQ4)
  • Cast iron cylinder heads, cathedral port — the same port design as the LQ4 (not aluminum, and not the LS2/rectangular-port head)
  • Higher-compression flat-top pistons (~10:1) plus a slightly hotter cam — this is what makes the extra power
  • ~345 HP stock
  • Used in: Cadillac Escalade, Chevy Avalanche/Silverado SS, GMC Sierra Denali
  • Common years: ~2002–2007
The Key Difference: Pistons and Compression — Not the Heads
This is the part most write-ups get wrong. Production LQ4 and LQ9 engines both use cast iron cathedral-port heads. The LQ9’s extra power over the LQ4 comes from its flat-top pistons (higher compression) and camshaft — not from a different cylinder head. Claims that the LQ9 has “aluminum LS2 rectangular-port heads” are incorrect: the rectangular-port head is a later Gen IV design (L92/LS3), and the LS2 itself uses a cathedral-port head.
Why the LQ9 Is Popular for Swaps:
  • Iron 6.0L bottom end (strong and cheap from salvage yards)
  • Higher factory compression and a slightly better cam than the LQ4
  • Responds very well to a cam-and-tune
Thinking About a Head Upgrade?
Because the LQ4 and LQ9 share the same cathedral-port head design, swapping “LQ9 heads onto an LQ4” gains you very little. The real head-upgrade path on a cathedral-port 6.0L is a set of better-flowing cathedral-port aluminum heads (or ported castings). If you want rectangular-port heads (L92/LS3 style), understand that they require a matching rectangular-port intake manifold and different injector/pushrod considerations — you can’t just bolt them to a cathedral-port intake. Verify port type, combustion-chamber volume, and intake/injector compatibility before buying.
Bottom Line:
The LQ4 and LQ9 are mechanically very close. The LQ9 mainly buys you higher compression and a slightly hotter cam, so it’s worth a small premium — but you’re paying for pistons and a cam, not a head upgrade. Either one is an excellent foundation for a swap.
Do you have an LQ4 or LQ9 in your build? What power level are you at?
