Lowering a Square Body C10 – Spindles vs Drop Springs
Lowering a 1973–1987 C10 is one of the most popular builds in the truck world. There are two main approaches: drop spindles or dropped springs/coils. Here’s how they compare.
Why Lower a C10?
  • The factory stance is tall and boxy-looking
  • A lowered C10 handles better and looks incredible
  • Classic mini-truck and restomod builds both use lowering
Option 1: Drop Spindles (Best for Mild Lowering)
Drop spindles move the wheel hub centerline lower, effectively lowering the front of the truck by 2–3" without changing the suspension geometry or spring rates. The ball joints, tie rods, and shocks all stay in their factory locations.
2.5" Front Drop Spindle Kit – Compatible with 1973–1987 Chevy C10 2WD – Includes rotors. Maintains factory suspension geometry for a comfortable, stock-like ride at reduced height.
Drop Spindle Pros:
  • Keeps factory spring rate and ride quality
  • Maintains good suspension geometry
  • Easy install (no spring compression needed)
  • No alignment issues
Drop Spindle Cons:
  • Limited drop (usually 2–3" max front)
  • Rear still needs separate lowering
Option 2: Dropped Springs (More Aggressive Drop)
Aftermarket lowering springs reduce front ride height 3–5" and are used when you want a more aggressive stance. Available as coil springs (front) and leaf springs (rear).
Typical C10 Lowering Setups:
  • Mild street: 3/4 drop (3" front, 4" rear)
  • Aggressive: 5/7 or 6/6 drop
  • Show truck/bagged: unlimited
Rear Lowering Options:
The C10 rear uses leaf springs. Lowering options include:
  • Flip kit (flip the rear axle from over-spring to under-spring) = 4" drop
  • Add-a-leaf removal
  • Replacement lowering leaf packs
Recommended Approach:
For a daily driver lowering build, 2.5" spindles up front + a flip kit in the rear gives a 2.5"/4" drop that looks great and still drives well.
What lowering setup are you running on your C10? Share your setup and measurements!
