If you’re shopping for a GMT900 truck or SUV with the 6.2L engine, you’ll encounter two engine codes: L92 and L9H. Here’s the complete breakdown of the difference.
L92 vs L9H – Quick Summary
| Feature | L92 | L9H |
| Displacement | 6.2L | 6.2L |
| Valvetrain | DOHC (VVT) | Same |
| AFM | No | No |
| Applications | Trucks (Silverado, Sierra) | SUVs (Tahoe, Suburban, Yukon, Escalade) |
| Horsepower | 403 hp | 403 hp |
| Torque | 417 lb-ft | 417 lb-ft |
| Fuel Injection | Sequential MFI | Sequential MFI |
The Reality: They’re Nearly Identical
The L92 and L9H are essentially the same engine. GM used different codes to differentiate between truck and SUV applications for emissions certification purposes. Internal components – pistons, rods, crankshaft, heads – are interchangeable.
Key Differences (Minor):
- Intake manifold configuration may differ slightly between applications
- ECU tuning differs for truck vs SUV weight ratings
- Exhaust manifolds differ based on application
Which Is Better for Swaps?
Both engines are popular LS swap candidates. The L92/L9H heads (rectangular port) are highly sought after for LS builds because they flow significantly better than the cathedral port heads on older LS engines.
Why No AFM on the 6.2?
Neither the L92 nor L9H uses AFM (Active Fuel Management). This is one of the reasons many buyers specifically seek out 6.2L trucks over the 5.3L – no AFM lifter concerns.
Parts Compatibility:
If you’re looking to modify either engine, aftermarket support is excellent. Cam kits, intakes, headers, and tune packages are all interchangeable between L92 and L9H.
Do you have an L92 or L9H in your GMT900? Share what mods you’ve done below!
