K2XX Subwoofer Install – Best Under-Seat Options
Adding a subwoofer to a K2XX Silverado/Sierra improves bass dramatically. The under-seat powered sub approach is the cleanest option.
K2XX Seat Design Considerations
The K2XX has a more complex front seat structure than older trucks. The front bench or bucket seats sit lower, leaving limited space underneath for large subwoofer enclosures.
The best-fitting under-seat subs for K2XX are compact powered units under 4" tall:
Top K2XX Under-Seat Subwoofer Picks:
1. JL Audio SB-GM-SLTK2/
JL Audio makes K2XX-specific subwoofer systems that mount under the rear seat. Exceptional sound quality and seamless factory integration.
2. Rockford Fosgate PS-8
The PS-8 is a thin powered 8" subwoofer that fits under the front or rear seat. 150W amplifier built in, plug-and-play setup.
3. Bazooka BTA8100FH
Bazooka’s compact tube-style subs work in K2XX trucks and provide decent bass for a budget price.
Signal Connection:
Use the head unit’s preamp outputs if you have an aftermarket unit like the Kissound 7" Double DIN. If keeping the factory radio, use a line output converter (LOC) to tap the rear speaker wires.
Power:
Run a dedicated power wire from the battery to the amp for clean, reliable power.
Tip: Set the low-pass filter at 80-100Hz for best integration with the full-range speakers.
