K2XX 8-Speed Shudder Fix – Common Issue Explained
The 8-speed 8L90 transmission in some 2014–2018 K2XX trucks (primarily 6.2L equipped) has a documented shudder issue. Here’s what causes it and how to fix it.
What Is the 8L90 Shudder?
A low-speed vibration or shudder felt between 40–65 mph under light throttle, particularly during gentle acceleration or cruise. It’s similar in feel to TCC (torque converter clutch) shudder.
Root Cause:
The shudder in the 8L90 is typically caused by:
  1. TCC (torque converter clutch) slipping before lockup
  2. Transmission fluid degradation (breaks down faster in the 8L90 due to tighter tolerances)
  3. Gear hunting (frequent shifts between gears at cruise)
GM TSB (Technical Service Bulletin):
GM has issued TSBs for the 8L90 shudder. Updates to the TCM (Transmission Control Module) calibration have been released that modify TCC lockup behavior.
Fix Options:
Option 1: GM Dealer Calibration Update
If your truck is still under warranty or extended powertrain warranty, the dealer can update the TCM calibration. This addresses the shift programming that causes hunting.
Option 2: Full Fluid Service
A complete fluid drain and fill with fresh Dexron VI often reduces or eliminates shudder caused by fluid degradation.
ACDelco Dexron VI ATF – OEM-specified fluid. Do a complete fill of approximately 11 quarts for the 8L90.
Option 3: Lubegard Shudder Fixx
Lubegard Instant Shudder Fixx – Add to the transmission fluid after a drain and fill to address TCC friction issues.
What Doesn’t Help:
Replacing the transmission without addressing fluid or calibration will result in the same shudder.
Has your K2XX 8-speed experienced shudder? What fixed it?
