Intercooler Upgrade for Duramax: What It Does, What to Buy, and How Much Power It Adds
The factory intercooler on LBZ and LMM Duramax trucks is adequate for stock power levels — but once you add a tune, larger turbos, or increased fueling, the stock unit becomes a restriction that limits power and raises EGTs.
WHAT AN INTERCOOLER DOES
  • Cools the compressed air from the turbo before it enters the cylinder
  • Cooler, denser air means more oxygen per cycle = more power
  • Reduces EGTs by lowering combustion temps
  • The factory unit is a bar-and-plate design with limited core volume
WHEN TO UPGRADE
  • When you’ve added a performance tune and feel EGTs climbing under load
  • When boost pressure recovers slowly after a gear change
  • When making 400+ rwhp on a tuned LBZ or LMM
WHAT TO LOOK FOR IN AN INTERCOOLER
  • Core dimensions: larger core = more cooling capacity
  • Bar-and-plate construction (stronger than tube-and-fin)
  • Proper inlet/outlet sizing to match your charge piping
  • OEM fitment — replaces the factory unit without modification
POPULAR OPTIONS
  • PPE High-Flow Intercooler: Direct-fit, significant volume increase over stock
  • Mishimoto Intercooler: Lighter weight, excellent thermal performance
INSTALLATION TIPS
  • Inspect all intercooler boots during installation — replace anything that looks tired
  • Torque all clamps evenly — T-bolt clamps are preferred over worm gear
  • Pressure test the system after install before driving
Recommended Parts
