Wiring an LS engine into a 1973–1987 C10 is the most intimidating part of the swap for most builders. But with a quality standalone harness, it’s much more manageable than you’d think. Here’s your guide.
The Two Main Approaches:
1. Standalone Engine Harness (Recommended)
A standalone LS harness is designed specifically for swaps. It strips out all the factory truck-specific wiring (anti-theft, HVAC controls, etc.) and leaves only what the engine needs to run. Your factory C10 body wiring remains completely separate.
Painless Performance 60508 – LS1 Standalone Harness (1998–2002) – The most popular and proven standalone option for LS1 swapped C10s.
What’s Included:
- ECM connectors and PCM connectors
- All engine sensor connectors pre-wired
- Throttle body (TPS, IAC) connectors
- Fuel injector connectors
- Ignition coil connectors
- Starts at the ECM and ends at each sensor/actuator
2. Modified Factory Truck Harness
Pull an LS harness from a donor truck and remove unnecessary connections. More work but can be cheaper if you’re comfortable with wiring.
Sensors Required:
- Crankshaft position sensor
- Camshaft position sensor
- MAP sensor (manifold absolute pressure)
- MAF sensor (on drive-by-cable LS1/LS6 systems)
- IAT sensor
- Coolant temp sensor
- Oil pressure sensor
- Throttle position sensor (TPS)
- IAC (idle air control) – carbureted-throttle LS engines
Power/Ground Requirements:
- Switched 12V for PCM (ignition on)
- Constant 12V (keep-alive memory)
- Chassis ground – critical for proper operation
PCM Tuning:
The PCM must be tuned for your specific setup (VIN, cam, injector size, no VATS). Use HP Tuners or an LS1 Edit tune before attempting to start the engine.
What harness setup did you use for your C10 LS swap?
