Talking 88–98 trucks that still gotta daily / tow, not weekend drag toys.
Basic tune-up first (boring but matters)
Most guys skip this and then complain it’s still a dog.
- AC Delco plugs and wires
- New cap/rotor if you’re TBI / early Vortec
- Clean MAF (if you have one), throttle body, IAC
- Fuel filter and air filter that actually flows (AC Delco, Wix, not the $4 special)
If this stuff’s tired, all the “mods” just make more noise.
Timing + throttle response
This wakes them up more than people think.
- On TBI, bump base timing 2–4° over stock (use the tan/black wire, do it right)
- Make sure you’re not knocking, listen and pull it back if it rattles
- Clean and lube throttle cable / check you’re getting full throttle
- Adjust TV cable on 700R4 so it kicks down like it should
Done right, it’ll feel like you added 20 hp even though you didn’t.
Exhaust that doesn’t kill low end
Everyone wants loud, then complains about towing power.
- Leave the stock Y-pipe unless it’s rotted, they actually flow decent
- Single 3” out the back, not dumped under the bed
- Mufflers that work good on these:
- Dynomax Super Turbo – nice tone, no drone, doesn’t kill torque
- Magnaflow 18" – deeper, a little more bark, still livable
- Don’t go dual 2.5" on a stock 5.7 “for power” – sounds cool, feels lazier off the line
Intake and small stuff
Don’t waste money on shiny junk.
- Keep stock air box, drop in a decent filter
- If you want a “cold air,” just open the bottom of the box and run fresh duct from the grille
- Electric fans help free a little power, but only if your cooling system is solid and wired right
- Make sure brakes aren’t dragging, front hubs aren’t cooked – truck feels slow when it’s fighting itself
Gears + converter (where it really wakes up)
Not “budget” exactly, but this is what actually makes it feel strong.
- If you’re on 33s with 3.42s, that’s your problem, not the engine
- 3.73 or 4.10s wake up a 5.7 more than any bolt-ons, especially on bigger tires
- A mild converter (like a 2200–2400 stall) in a 4L60E truck makes it way snappier around town
Warning: slapping “performance” parts on a worn-out GMT400 just makes its problems louder. Fix the base, then wake it up.
