Build threads are one of the best parts of FSC — and starting one is easier than you think. Here’s how to create a great build thread that other members will follow and engage with.
Why Start a Build Thread?
- Documents your progress (great reference when something breaks later)
- Gets you advice from people who’ve done similar builds
- Motivates you to keep going when you see others following along
- Helps other members who are planning similar projects
Where to Post Your Build Thread
Post in the Builds & Projects section:
- In Progress — for active builds you’re working on
- Completed Builds — for finished projects you want to showcase
Even if you’ve had the truck for a while, you can still document what you’ve done and pick up where you are now.
What Makes a Good Build Thread?
1. Introduction Post
Start with the basics:
- Year, make, model, engine, trans
- Current condition and mileage
- Your goal — what kind of build is this? (Street, off-road, daily, show truck, performance?)
- Photos of the truck as it is RIGHT NOW — before shots are just as important as afters
2. Consistent Updates
Post when you:
- Install something new
- Diagnose and fix a problem
- Hit a milestone (first startup after a rebuild, first trail run, dyno day, etc.)
Even a “no progress this month” update keeps followers engaged.
3. Photos Are Everything
Shoot photos in good light. Close-ups of parts before and after installation are especially helpful. Before, during, and after the install sequence is gold for people searching how-to info.
4. Part Numbers and Links
When you install something, note the part number, brand, and where you got it. Others will search your thread for exactly that information.
Thread Title Format Suggestions
- “[YEAR] [MODEL] — [BUILD GOAL]” example: 2003 Silverado 2500HD — Daily Driver Build
- “[ERA] C/K [GOAL] Build” example: Squarebody K10 Resto-Mod Build
Keep It Going
The best build threads span years and show the full journey — including the setbacks. Don’t be afraid to post when things go wrong — that’s where the best learning happens.
