Improperly loaded truck beds are a leading cause of handling problems, trailer sway, and component damage. Here’s how to do it right.
Understanding Payload:
Your truck’s GVWR (Gross Vehicle Weight Rating) minus the truck’s curb weight equals payload capacity. This is the maximum weight of passengers, cargo, and trailer tongue weight combined.
Never exceed your truck’s payload rating. Overloading causes:
- Accelerated suspension wear
- Brake fade
- Tire overload (blowout risk)
- Chassis fatigue
- Voided warranty
Finding Your Payload:
The yellow payload sticker on the driver’s door jamb shows your specific truck’s payload rating. This varies by options and configuration.
Proper Load Distribution:
- Center of gravity: Load heavy items low in the bed and toward the cab
- Balanced side-to-side: Equal weight on both sides prevents lean
- Front-heavy (not rear): Avoid loading heavy items only at the tailgate — it reduces front tire contact
When Towing:
- Keep 60% of trailer load ahead of the trailer axle
- Tongue weight should be 10-15% of total trailer weight
- For heavy loads, use a weight distribution hitch to level the truck/trailer
Securing the Load:
- Use ratchet straps rated for the load weight
- Anchor to factory tie-down rings in the bed (verify their rating)
- Cover loose materials to prevent road debris hazards
The Dee Zee Crossover Tool Box keeps heavy tools forward and secured rather than sliding loose in the bed.
