Active Fuel Management (AFM) / Displacement on Demand (DoD) is the cylinder deactivation system used on most 2007–2013 GMT900 trucks with the 5.3L V8. While designed to improve fuel economy, it’s also the root cause of the infamous lifter failure that has affected tens of thousands of trucks. Here’s how to disable it.
Why Disable AFM/DoD?
- Lifter failure is directly linked to AFM operation — the AFM lifters (used in cylinders 1, 4, 6, 7) have a collapsing mechanism that wears faster than standard lifters
- Disabling AFM keeps all 8 cylinders firing at all times, preventing the wear pattern that destroys the AFM lifters
- The truck runs and drives identically — no performance or economy penalty in most real-world driving
Option 1: Range Technology AFM Disabler (Plug-and-Play)
The easiest method. The Range Technology RA003B AFM/DFM Disabler plugs into your OBD-II port and sends a signal to the PCM to keep AFM deactivated — no tuning, no programming, no check engine light.
Pros: Reversible, no permanent changes, works immediately
Cons: Must be plugged in at all times; the OBD port is occupied
Compatible with: 2007–2013 5.3L GMT900 trucks (Silverado, Sierra, Tahoe, Suburban, Yukon)
Option 2: Custom Tune (HPTuners or EFI Live)
A proper tune via HPTuners or EFI Live can permanently disable AFM in the PCM calibration. This is the preferred method if you’re already having the truck tuned for other reasons.
Pros: Permanent, frees up OBD port, can combine with other tune changes
Cons: Requires a tune ($150–$300+ from a tuner), less reversible
Option 3: AFM Delete Kit (Mechanical)
If you’re already doing an engine rebuild or replacing lifters, do a full AFM delete: replace all 8 AFM lifters with standard hydraulic lifters, and replace the AFM intake manifold with a non-AFM unit. Also requires a tune to disable AFM in the PCM.
This is the permanent fix — removes the AFM system hardware entirely.
Which Option Is Right for You?
| Situation | Recommended Option |
| Preventive (truck runs fine) | Range Technology plug-in disabler |
| Already tuning for performance | Custom tune with AFM disabled |
| Engine apart for lifter replacement | Full AFM delete kit + tune |
| Lifters already failed | Delete kit + tune + rebuild |
Do I Need to Disable It?
Not every 5.3L will have lifter failure — some trucks go 200K+ without issue. But the risk is highest between 80K–150K miles. The Range device is inexpensive insurance compared to a $3,000+ lifter job.
