HEI Distributor Upgrade on Squarebody Trucks: 305, 350, 454 (1973–1987)
The factory HEI on most 1973–1987 Squarebody trucks gets weak with age. Caps crack, rotors burn, and the internal module fails without warning. A fresh HEI or a quality rebuilt unit fixes cold start issues, rough idle, and flat spots instantly.
STOCK LIMITATIONS
  • Factory HEI module fails between 60k–120k miles with no warning
  • Worn advance weights cause timing to hang or not advance properly
  • Cracked cap leads to moisture intrusion and misfires
  • Stock coil output drops with mileage
BEST MODS
  • Drop-in replacement HEI with high-output coil (PerTronix, MSD, or Accel)
  • Recurve the advance springs to match your cam and compression
  • Replace cap and rotor regardless when doing any HEI work
  • Optionally upgrade to a billet distributor if running forced induction or a radical cam
GAINS
  • Crisper starts in all temperatures
  • Smoother idle
  • Slightly better fuel economy from cleaner combustion
  • More responsive throttle in the mid-range
SUPPORTING MODS
  • Check plug wires — spiral core wires reduce interference and last longer
  • New plugs gapped to 0.045" for stock or mild builds
  • Verify timing after installation — aim for 34–36° total advance
WHAT TO AVOID
  • Cheap one-wire conversion units that fail in 6 months
  • Not recurving the advance — ruins the benefit of a fresh unit
  • Swapping distributor without rechecking total timing
  • Reusing old plug wires with a new distributor
CHEAP VS PROPER FIX
  • Cheap: new cap and rotor only — works short term on a healthy module
  • Proper: full HEI replacement with a recurved unit and quality wires
Recommended Parts
  • PerTronix D1060 Flame-Thrower HEI Distributor for Chevy SB/BB: Amazon.com
  • JDMSPEED 10.5mm Spark Plug Wire Set for HEI SBC BBC 350 454: Amazon.com
  • MSD 84335 HEI Distributor Cap and Rotor Kit Red: Amazon.com
