GMT900 Rear Wheel Arch Rust – Early Signs to Watch For
Rear wheel arch rust is a known weak point on the 2007–2013 GMT900 Silverado and Sierra. The inner wheel arch area traps moisture and road salt, leading to rust that starts from the inside out. Catching it early is the key to a manageable repair.
Why GMT900s Rust Here:
The rear wheel arch has a multi-layer construction where the outer skin meets the inner structure. Moisture and debris accumulate in the lower seam and the inner arch area, creating a perfect rust environment. Trucks from the northern US, Canada, and any high-salt environment are especially vulnerable.
Early Signs to Watch For:
  1. Paint bubbling along the bottom edge of the rear wheel arch (inside the fender lip)
  2. Brown discoloration inside the wheel well at the arch
  3. Small pinholes in the outer skin near the arch seam
  4. Soft spots when pressing on the arch panel
How to Inspect:
  • Remove the rear inner fender liner (8-10 push-pin clips)
  • Inspect the inner arch structure with a flashlight
  • Look for rust holes, rust scale, or wet areas
  • Check where the arch meets the bed floor
Repair Options:
Early Stage (Surface Rust):
Moderate Stage (Rust Through):
  • Requires panel repair or patch welding
  • Local body shop or DIY with patch panels
Prevention:
  • Annual undercoating of wheel arches and inner panels
  • Flush inner arch areas with fresh water after winter driving
  • Install inner fender mud guards to reduce debris accumulation
Cost to Repair:
  • DIY (surface rust): $50–$150 in materials
  • Body shop (patch panels): $500–$1,500 per arch
  • Body shop (full arch replacement): $1,500–$3,000
Have you dealt with rear arch rust on your GMT900? Share your approach below.
