GMT900 Dash Cracking Issues (Why It Happens and Fix Options)
GMT900 Dash Cracking Issues — Why It Happens and What You Can Do
Cracked dashboards are one of the most talked-about interior problems on 2007–2013 Silverado, Sierra, Tahoe, Yukon, and Suburban trucks. If you’re dealing with a split dash, you’re not alone — it’s almost universal on high-sun-exposure trucks of this era.
Why Does the Dash Crack?
The factory dashboard on GMT900 trucks is made from a vinyl-covered ABS plastic substrate. Over time:
  • UV exposure breaks down the vinyl surface, causing it to harden, shrink, and crack
  • Heat cycles from repeated warming and cooling cause the material to stress and split
  • Airbag door stress — cracks frequently start around the passenger airbag door seam, where the material is thinnest and most stressed
  • Ventilation areas — cracks also commonly appear near the defroster vents where heat concentrates
The more sun the interior sees, the worse and faster it cracks. Black interiors absorb more heat and are particularly prone.
Common Crack Locations
  • Across the top of the dash (near the windshield)
  • Along the passenger airbag door seam — the most common and most dramatic
  • Across the defroster vent openings
  • Near the instrument cluster hood
Fix Options
Option 1: Dash Cover Mat (Cheapest Fix)
A custom-fit dash cover sits over the existing dash, covering cracks and protecting from further UV damage.
Pros:
  • Inexpensive ($30–$60)
  • Easy to install — no removal required
  • Protects against further cracking
  • Available in OEM colors (black, charcoal, tan, etc.)
Cons:
  • Doesn’t fix the underlying damage
  • Slightly changes the look and feel of the interior
  • Can trap heat if poorly ventilated
  • Quality varies — cheap thin covers look and feel cheap
Best for: Budget-conscious owners who want to hide cracks quickly.
Option 2: Dash Repair / Filler
Crack filler products or vinyl repair kits can partially hide cracks. Results vary significantly:
  • Works best on early-stage hairline cracks
  • Does not hold up long-term if the dash is still flexing
  • Can look worse than the crack if poorly applied
Verdict: Not recommended as a long-term solution.
Option 3: Used OEM Dash Replacement
Sourcing a used dash from a salvage yard is a popular option.
Pros:
  • Factory look and feel
  • Often significantly cheaper than new
  • Can find matching color easily
Cons:
  • Used GMT900 dashes are frequently cracked themselves — inspect carefully
  • Requires full dash removal — significant labor (~4–8 hours)
  • Airbag components must match (year and trim-level specific)
Important: If replacing a dash that includes a passenger airbag, the airbag housing must be compatible with your vehicle. Never install a non-matching airbag assembly.
Option 4: New OEM or Aftermarket Dash Panel
New reproduction dash panels are available for GMT900 trucks. These are significantly more expensive than a used dash but come crack-free.
Pros:
  • Brand new — no existing cracks
  • Full match to factory spec
Cons:
  • Expensive ($400–$800+ for the panel alone)
  • Same labor-intensive installation
Prevention
If your dash is still crack-free or in early stages:
  • UV protectant spray — Apply a quality protectant like 303 Aerospace Protectant regularly to slow UV breakdown
  • Windshield sunshade — The single most effective thing you can do. Keeping the interior cool dramatically slows dash degradation
  • Park in shade when possible — Obvious, but highly effective
  • Tinted windows — Reduces UV transmission significantly
Bottom Line
If your dash is cracked, the dash cover is the fastest and most cost-effective solution. It won’t fix the problem but it hides it cleanly and prevents further UV damage.
If you want the interior looking like new, budget for a full dash swap with a clean used or new dash — but inspect any used dash thoroughly before buying, and expect several hours of labor.
Whatever you do, start using UV protectant and a windshield shade to stop the damage from progressing.
Recommended Products
