GMT900 Backup Camera Install — Factory vs Aftermarket Wiring
Adding a backup camera to a 2007–2013 Silverado, Sierra, Tahoe, or Yukon is a great upgrade for safety and convenience. Most early GMT900s came with no camera at all — and even the ones that did often had low-resolution, unreliable units. Here’s how to add one properly.
Factory Limitations
- Most 2007–2011 GMT900 trucks have no backup camera from the factory
- Late-model trucks (2012–2013) may have an optional camera, but it’s still low resolution
- Factory radios on non-upgraded trucks have no video input
- No trigger wire is pre-run to the rear of most non-camera vehicles
Wiring Basics
Before you start, understand these three key connections:
1. Reverse Trigger Wire
The camera needs to know when the truck is in reverse so it activates automatically. The easiest source is the reverse light circuit at the rear of the truck.
- Tap into the positive wire of the reverse light bulb socket
- This wire goes positive (~12V) when the truck is shifted into reverse
- Trace it to the tail light assembly — you can access it through the trunk/tailgate area
2. Video Input to Head Unit
Your aftermarket head unit needs to accept a camera input. Most modern units have:
- RCA input (yellow video jack) — common on older units
- Digital/HDMI input — on newer units
- Dedicated rear camera input with automatic activation
Run a video RCA cable from the camera to the head unit. Route it through the interior, away from power wires to avoid interference.
3. Ground
Ground the camera directly to a clean chassis ground near the camera mounting location. A poor ground will cause flickering image, static, or no picture.
Installation Options
Option A: Add to Aftermarket Head Unit
If you’ve already upgraded to an aftermarket head unit with a rear camera input, this is straightforward:
- Mount camera in or near the center brake light housing, license plate area, or tailgate handle
- Run camera power to the reverse trigger wire
- Run video cable through the interior to the head unit
- Connect ground
- Set the head unit to display camera when reverse is detected
Option B: OEM-Style Integration
For the cleanest look, use an OEM-style camera that mounts in the factory location (typically the license plate area or a tailgate handle camera). These look factory-installed and match the trim.
Option C: Mirror Display Camera
A self-contained rearview mirror with a built-in screen. The camera mounts at the back, and the mirror replaces or covers the factory unit. Simpler wiring since the display and camera are a matched set.
Common Problems and Fixes
| Problem | Cause | Fix |
| No image in reverse | Trigger wire not connected or reversed | Check reverse trigger wire — should be +12V in reverse |
| Flickering image | Poor ground or loose connection | Clean ground, re-secure connections |
| Image only appears randomly | Intermittent trigger or camera connection | Inspect and re-solder connections |
| Static or noise in image | Video cable routed near power wires | Re-route video cable, add ferrite bead |
| Image too dark | Cheap camera with poor low-light spec | Upgrade to a better camera with wide-angle IR night vision |
Tips for a Clean Install
- Use split loom and cable clips to route wires cleanly through the interior
- Test the full system before buttoning up panels — saves a lot of frustration
- If routing through the tailgate on a pickup, use a flexible conduit through the tailgate hinge area
- Protect any exterior connections with heat shrink or self-amalgamating tape
Bottom Line
A backup camera install on a GMT900 is a one-afternoon job with the right materials. The trickiest part is running the video cable cleanly from the rear of the truck to the head unit. Take your time with the routing and test before closing up.
Don’t go cheap on the camera — a $15 Amazon unit will have poor image quality and fail quickly. Spend $40–$80 on a quality unit with night vision and waterproof rating.
Recommended Products
