GMT900 5.3 Oil Consumption Issues (2007–2013 Silverado Sierra Tahoe Yukon)
GMT900 5.3 Oil Consumption Issues (2007–2013)
If you own a GMT900 truck with the 5.3L V8 and you’re constantly topping off oil between changes, you’re not alone. This is one of the most widespread issues on the platform, and it has a clear root cause — the Active Fuel Management (AFM) system.
Symptoms to Watch For
  • Oil level dropping 1–2 quarts between changes without visible leaks
  • Blue or gray smoke on cold startup
  • Fouled or oil-soaked spark plugs
  • Oil residue or wetness inside the intake air tube
  • Burning smell from the exhaust under load
If you’re seeing two or more of these, AFM oil consumption is almost certainly your culprit.
What’s Causing It
Active Fuel Management (AFM) — The cylinder deactivation system creates pressure fluctuations that pull oil past the valve stem seals and into the intake. This is the primary cause on the vast majority of affected trucks.
Valve cover PCV design — The PCV system routes blow-by gases back into the intake. On GMT900 trucks, the stock design doesn’t separate oil effectively, allowing it to be ingested by the engine.
Worn piston rings — Long-term oil consumption and poor maintenance can accelerate ring wear, compounding the problem.
Excessive idling — Extended idle time at low RPM reduces oil pressure variance and allows more blowby accumulation.
How to Fix It
Short-term fixes:
  • Install an oil catch can between the valve cover PCV port and the intake — this filters oil mist before it re-enters the engine
  • Upgrade to the updated valve cover with improved PCV baffling (GM part available or aftermarket equivalent)
  • Switch to a high-quality full synthetic oil and change it more frequently (every 5,000 km or sooner)
Permanent fix:
  • AFM Delete — Remove and bypass the AFM system entirely using a delete kit (lifters, valley cover, and a tune). This eliminates the root cause and is the only real long-term solution.
  • AFM Disable — A plug-in device (like the Range Technology AFM Disabler) keeps the engine in V8 mode at all times. This stops the active problem but does not reverse any existing wear.
Prevention and Ongoing Maintenance
  • Check your oil level every 1,000 km — don’t wait for a warning light
  • Use a quality synthetic oil and a good filter (Wix, AC Delco, Mobil 1)
  • Avoid extended idling, especially when cold
  • Address any misfires or plug fouling immediately — they signal the problem is advancing
Bottom Line
A catch can is a cheap and helpful band-aid — it reduces oil ingestion and keeps your intake cleaner. But it does not fix the AFM system. If you want to stop the consumption and protect your engine long-term, the AFM delete is the right move. The cost is higher upfront, but it eliminates the failure point entirely.
At minimum, disable AFM immediately and monitor your oil level closely until you can budget for the full delete.
Recommended Products
