GMT800 Towing Capacity Chart – 1500, 2500, and 3500 (1999–2006)
If you’ve ever wondered how much your GMT800 can actually pull, here’s the full breakdown by engine and axle ratio. These are factory ratings — your actual capacity depends on your specific build, options, and condition.
GMT800 1500 Towing Capacity (1999–2006)
Engine Axle Ratio Max Tow Rating
4.3L V6 (LU3) 3.42 5,000 lbs
4.8L V8 (LR4) 3.42 6,000 lbs
4.8L V8 (LR4) 3.73 7,000 lbs
5.3L V8 (LM7/L59) 3.42 7,500 lbs
5.3L V8 (LM7/L59) 3.73 8,100 lbs
5.3L V8 (LM7/L59) 4.10 8,500 lbs
Notes:
  • Extended cab and crew cab configurations generally reduce max tow by 200–500 lbs due to added weight.
  • Short bed vs. long bed does not directly affect tow rating but affects weight distribution.
  • 1500 models require the Trailering Package (RPO Z82) to hit max ratings. Without it, ratings are lower.
GMT800 2500 Towing Capacity (1999–2006)
6.0L V8 (LQ4) 3.73 10,000 lbs
6.0L V8 (LQ4) 4.10 11,500 lbs
8.1L V8 (L18) 4.10 12,000 lbs
6.6L Duramax LB7/LLY 3.73 12,000 lbs
Notes:
  • 2500 trucks have a heavier frame, upgraded suspension, and larger brakes vs. the 1500.
  • The 8.1L gas engine and Duramax diesel were optional and significantly boost towing capability.
  • GVWR on 2500 models runs 8,600–9,200 lbs depending on cab/bed combo.
GMT800 3500 Towing Capacity (2001–2006)
6.0L V8 (LQ4) 4.10 13,000 lbs
8.1L V8 (L18) 4.10 15,000 lbs
6.6L Duramax LB7/LLY 3.73 15,000+ lbs
Notes:
  • 3500 DRW (dually) models can exceed 15,000 lbs with proper setup.
  • Always verify your truck’s GCWR (Gross Combined Weight Rating) — it’s on the door jamb sticker.
  • Fifth wheel ratings are higher than conventional hitch — check your RPO codes for hitch type.
How to Verify Your Truck’s Actual Rating
  1. Check the door jamb sticker — GVWR and tire/load info is there.
  2. Decode your RPO codes — look for GU6 (3.42), GT4 (3.73), GT5 (4.10) for axle ratio, and Z82 for the Trailering Package. Or photograph the whole label and run it through the GM RPO Decoder.
  3. Pull your VIN — NHTSA has a free lookup tool if your sticker is worn.
Reminder: Tow ratings assume a properly maintained truck. Worn brakes, old trans fluid, and soft shocks all reduce your safe towing threshold even if the numbers on paper look fine.
Drop your setup below — engine, axle ratio, and what you’re pulling. Happy to help cross-reference.
