GMT800 Rocker Panel Rust – How Bad Is Too Bad?
The 1999–2006 GMT800 Silverado/Sierra is prone to rocker panel rust, especially in northern states. Here’s how to evaluate the severity and determine your repair options.
Why GMT800 Rockers Rust:
The lower rocker panels on GMT800 trucks have a hemmed edge where two layers of steel are rolled together. This seam traps moisture and salt, leading to rust that starts from the inside and eventually perforates the outer skin.
Stage 1: Surface Rust and Bubbling
Paint bubbling along the lower rocker edge. No perforation yet. Treatment: strip to bare metal, treat with converter, seam seal, prime, and paint.
Rust-Oleum 2-in-1 Rust Reform & Seal Spray – Apply to the stripped surface and inside the rocker seam before closing up.
Stage 2: Light Perforations
Small holes appear along the lower seam. The rest of the panel is solid. This can be addressed with weld-in patch panels or slip-on rocker covers.
Stage 3: Extensive Perforation
Large rust holes, soft spots, possible inner structure involvement. Full rocker panel replacement required.
Stage 4: Inner Structure Affected
Rust has progressed into the cab corner structure and inner floor. At this point, the repair scope expands significantly and may not be cost-effective on a high-mileage truck.
The “Too Bad” Threshold:
If the rockers have Stage 3+ rust AND the cab corners and floor are also rusted through, the truck may cost more to repair properly than it’s worth. Use this as a hard negotiating point when buying.
Repair Cost Estimate:
  • Stage 1 DIY treatment: $50–$150
  • Stage 2 slip-on covers (cosmetic): $200–$500
  • Stage 3 weld-in replacement: $800–$2,000 per side (shop)
What does your GMT800 rocker situation look like?
