GMT800 Manual Swap – What's Involved?
Converting your 1999–2006 GMT800 automatic to a manual transmission is an uncommon but rewarding swap. Here’s what’s actually involved.
Why Manual Swap a GMT800?
  • More engaged driving experience
  • Manual transmissions are generally simpler and more durable
  • Some owners prefer the control of a clutch pedal
Factory Manual Trans Options on GMT800:
The GMT800 was actually available with a manual transmission from the factory:
  • NV3500 5-speed (lighter duty, used in 1500s)
  • NV4500 5-speed heavy duty (used in 2500HD/3500HD)
  • Allison 1000 6-speed (used in Duramax)
Swap Components Needed:
  1. Manual transmission (NV4500 or NV3500 from donor truck)
  2. Clutch pedal assembly (mount, master cylinder, linkage)
  3. Clutch hydraulic system (master and slave cylinder)
  4. Flywheel (must match manual trans)
  5. Clutch disc and pressure plate
  6. Manual-specific driveshaft (different length)
  7. ECM reprogramming (automatic trucks need tune for no-trans control)
The Pedal Box:
The manual pedal box is the most complex part of the swap. The firewall needs to be modified to accept the clutch pedal bracket.
ECM Considerations:
The GMT800 ECM communicates with the 4L60E for shift control. If you remove the automatic, you need a tune that removes all transmission references.
For Performance LS Builds:
T56 Magnum is a popular 6-speed choice for GMT800 V8 trucks building for performance. Requires transmission tunnel modification but provides excellent gear ratios.
ACDelco Dexron VI – The NV3500 and NV4500 use gear oil, but this trans fluid is noted for reference on other drivetrain mods.
Have you done a manual swap on a GMT800 truck? Share your build!
