1999–2006 Chevy Silverado / GMC Sierra (GMT800 Platform)
If you own a GMT800, upgrading the lighting is one of the easiest and highest-impact improvements you can make. These trucks sit in the perfect middle ground — modern wiring, simple electronics, and very few compatibility problems compared to newer trucks.
This guide covers every major light on the truck so you can plan a full refresh or LED conversion in one shot.
Why Upgrade GMT800 Lighting?
Factory halogen lighting on these trucks is dated by today’s standards.
Common complaints:
Weak headlights
Poor reverse visibility
Dim interior lighting
Slow brake/turn response
LED upgrades fix all of this while reducing power draw and modernizing the truck instantly.
Headlight & Front Lighting
Headlights
Low Beam — 9006
High Beam — 9005
Fog Lights
1999–2002: 880
2003–2006: 9145 (H10)
Front Signals / Markers
Turn Signals — 3157 / 3157NA
Parking Lights — 3157
Side Markers — 194
Low beams are the biggest improvement you’ll notice. A quality LED set dramatically improves nighttime driving.
Rear Lighting
GMT800 rear lighting is simple and consistent.
Tail / Brake / Turn — 3157
Reverse Lights — 3157 or 921
Third Brake Light — 921
Rear Markers — 194
License Plate — 194
Reverse lights are one of the best upgrades on these trucks. LED replacements make backing up at night far easier.
Interior Lighting
Dome Light — 211-2 / 578
Map Lights — 194 / 168
Courtesy Lights — 194 or 74
Glove Box — 194
Cargo Light — 912
Engine Bay Light — 93 / 1156
A full interior LED swap completely changes the cab — brighter, cleaner, and more usable.
Common LED Conversion Issues
Hyperflash (fast blinking signals)
Occurs after installing LED turn bulbs.
Fix:
Load resistors, or
LED-compatible flasher relay (better solution)
DRL quirks
Some GMT800 trucks run reduced-power high beams as daytime running lights. Certain LEDs may flicker.
Solutions include DRL-compatible bulbs or disabling DRLs.
Recommended Upgrade Order
Stage 1 — Safety
Low beams
High beams
Reverse lights
Stage 2 — Visibility
Brake and turn signals
Front signals
Fog lights
Stage 3 — Comfort
Interior lighting
License plate lights
Cargo and engine bay lights
Final Thoughts
GMT800 trucks are one of the easiest GM platforms to modernize. Nearly every bulb is plug-and-play, and a full lighting refresh makes the truck feel years newer without major cost or wiring work.
One weekend and a box of bulbs can completely change how the truck looks and drives at night.
