GMT800 Leveling Kit vs 6 Inch Lift – Ride Quality Comparison
If you’re deciding between a leveling kit and a full lift on your GMT800, here’s the honest breakdown on what each actually does to how the truck drives.
Leveling Kit (1.5"–2.5" front lift)
A leveling kit raises the front of the truck to sit level with or slightly higher than the rear. On GMT800s, these trucks sit nose-down from the factory, so a level kit corrects that rake.
What it does to ride quality: Minimal impact when done right. Most leveling kits on GMT800s use either coil spring spacers or strut spacers. A quality spacer kit (Rough Country, Supreme Suspensions, ReadyLift) does not significantly change the ride character. A cheap stamped-steel spacer can add harshness.
What changes:
  • CV angles increase slightly — not an issue at 1.5"–2" lifts
  • Factory control arm geometry is preserved
  • No alignment issues beyond a front toe adjustment
  • Tires: Most 1500s can run 285/70R17 or 33" tires with a leveling kit, sometimes with minor trimming
Pros:
  • Low cost ($50–150 for most kits)
  • DIY-friendly, 2–3 hour job
  • Retains factory ride quality
  • No UCAs needed
Cons:
  • Limited lift — 2.5" is about the max before CV wear becomes a concern
  • Doesn’t do much for ground clearance compared to a full lift
  • Can’t run 35s+ without rubbing on most GMT800s
6 Inch Lift Kit
A 6" lift is a system — typically involving new struts, top plates, control arms, and sometimes adjustable lower control arms and new shocks all around.
What it does to ride quality: This is where it gets real. A proper 6" lift on a GMT800 (think Bilstein 5100/6112 setup with aftermarket UCAs) can actually ride quite well — better than stock in some cases if the shock valving is right for your weight and use. A cheap coil spacer + add-a-leaf “6 inch lift” with stock shocks is harsh and should be avoided.
What changes:
  • UCAs (upper control arms) are required at 6" — factory UCAs can’t handle the geometry at that height without binding or premature wear
  • Alignment needs to be done carefully — some shops won’t align lifted trucks, find one that will
  • CV angles are steep enough to accelerate wear if geometry isn’t corrected
  • Tires: 35s are very doable at 6", 37s possible on long-travel setups with trimming
Pros:
  • Significant ground clearance
  • Aggressive stance
  • Can run 35"–37" tires depending on setup
  • Better off-road capability
Cons:
  • Cost: $1,500–4,000+ installed depending on kit quality
  • Increased wear on ball joints, CV axles, and wheel bearings over time
  • Alignment is critical and needs attention every 1–2 years
  • Highway manners suffer slightly — high-speed steering feel is less planted than stock
Ride Quality Head to Head
Factor Leveling Kit 6" Lift (quality kit) 6" Lift (budget)
Everyday comfort Essentially stock Good to excellent Harsh
Highway stability Stock Slightly reduced Reduced
Off-road performance Minor improvement Significant Moderate
Tire clearance 33" max (most trucks) 35"–37" 35"
Cost Low High Moderate
DIY feasibility Easy Moderate-hard Moderate
Recommendation
If you want a clean, level look and don’t need to run 35s: leveling kit. It’s 90% of the look for 10% of the cost.
If you’re running 35s or bigger, need ground clearance, or want a true off-road setup: 6" lift with quality UCAs and shocks. Don’t cut corners on the kit — a budget 6" lift is the worst of both worlds.
Drop your year, current setup, and what you’re trying to accomplish — happy to point you in a direction.
