If your 4.8, 5.3 or 6.0 GMT800 shows good oil pressure on a cold start and then sags low at idle once it’s warmed up, you’re not alone — this is one of the most common questions on these trucks. It’s also one of the most misdiagnosed.
Low oil pressure at hot idle is a symptom, not a diagnosis. It can be something cheap (a bad filter, a tired sending unit, thin or contaminated oil) or something serious (a worn oil pump, a pickup tube O-ring sucking air, or bearing wear). The only way to tell the difference is to verify the actual pressure with a mechanical gauge before you spend money.
We put together a full diagnostic and repair walkthrough here:
GMT800 Hot-Idle Low Oil Pressure: 5.3L and 6.0L Diagnosis and Pickup Tube O-Ring Guide
That article covers confirming the reading, the sensor vs. sensor-screen question (and which trucks actually have the screen), the pickup tube O-ring, the full cause tree, the oil pan job, and the 2WD vs 4WD difference.
Use this thread to compare notes
If you’re chasing this, post your truck and your numbers. The more detail, the more useful the answers:
- Year and model (Silverado / Sierra / Tahoe / Suburban / Yukon / Yukon XL)
- Engine and RPO if you know it (LR4 4.8, LM7 / L59 / L33 5.3, LQ4 / LQ9 6.0)
- 2WD or 4WD
- Mileage
- Oil viscosity and filter brand you’re running
- Cold-start oil pressure
- Fully warm idle oil pressure
- Pressure at raised RPM, if you tested it
- Was the reading verified with a mechanical gauge, or is this the dash gauge?
- Did you replace the sensor / sender? The screen (AFM trucks)? The pickup tube O-ring?
- Was there debris or metal in the pan when you opened it up?
- Final result — what actually fixed it?
A couple of ground rules
Parts-cannon guessing is not a substitute for a mechanical gauge. Replacing a sensor before you’ve verified the fault just hands you a false diagnosis. Confirm the reading first.
For anything in the oiling system — sender, pickup tube O-ring, oil pan gasket — stick with genuine GM / ACDelco or confirmed OEM-quality parts. A cheap part that reads wrong or leaks can cost you an engine.
And if your truck is making knock or heavy ticking, or you’ve found metal in the oil, this thread is not the place to wait for replies — that’s a stop-driving-and-inspect situation.
Post your symptoms, engine, mileage and what fixed it. Real readings from real trucks help the next owner who searches this.
