If you’re wrenching on a GMT400 (1988–1998) Silverado, Sierra, Suburban, Tahoe, or Yukon, this is a quick-reference torque list you can actually use in the garage.
This comes straight from the FSC Tech Packs.
Save it. Bookmark it. Print it.
Engine & Drivetrain Torque Specs
| Component | Torque Spec |
| Cylinder head bolts | 65 ft-lb / 22 ft-lb / 90° sequence |
| Intake manifold | 35 ft-lb |
| Exhaust manifold | 18 ft-lb |
| Rocker arms | 22 ft-lb |
| Oil pan | 12 ft-lb |
| Flexplate | 60 ft-lb |
| Crank pulley | 110 ft-lb |
| Bellhousing | 35 ft-lb |
Notes:
Always follow proper head bolt sequence.
Replace torque-to-yield bolts where required.
Clean threads and use correct sealant where applicable.
Suspension & Steering Torque Specs
| Upper control arm | 90 ft-lb |
| Lower control arm | 130 ft-lb |
| Ball joints | 70 ft-lb |
| Tie-rod end | 45 ft-lb |
| Steering box to frame | 70 ft-lb |
| Hub nut | 155 ft-lb |
| Caliper bracket | 129 ft-lb |
| Caliper slide pins | 25 ft-lb |
These numbers matter. Under-torqued suspension components lead to clunks. Over-torqued hardware ruins bushings and threads.
Driveline & Axles
| Driveshaft U-joint strap bolts | 15 ft-lb |
| Differential cover | 30 ft-lb |
| Pinion nut | 220 ft-lb |
| Leaf spring shackle | 75 ft-lb |
| Transmission crossmember | 45 ft-lb |
If you’re resealing a diff or swapping gears, follow correct preload procedures — don’t just hammer the pinion nut.
Body & Frame
| Bed to frame | 75 ft-lb |
| Cab mount | 85 ft-lb |
| Seat mount | 30 ft-lb |
| Bumper brackets | 70 ft-lb |
| Spare tire carrier | 45 ft-lb |
Cab mount torque is critical on rust-belt trucks. Recheck after first drive if mounts were replaced.
Why This Matters
Most GMT400 trucks are 25–35 years old now. Threads are tired. Hardware has been reused. Previous owners guessed.
Stop guessing.
Use correct torque. Prevent:
Warped manifolds
Loose steering boxes
Vibration issues
Brake failures
Frame cracks
FSC Tech Pack Series
This post is part of the FullSizeChevy.com Tech Pack series. More torque sheets and quick-reference guides are coming for:
GMT800
GMT900
K2XX
Duramax platforms
If you want printable PDFs or laminated garage versions, drop a reply.
Built for the Full-Size community.
