The GMT400 generation (1988–1998) is one of the most DIY-friendly truck platforms ever made. Robust, parts-everywhere, and relatively simple electronics. That said, there are known problem areas every owner should be aware of. This is the master list.
Engine Issues
TBI (1988–1995): Throttle Body Injection
MPFI Spider Injector Failure (Vortec 4.3 V6, Vortec 5.0/5.7 1996–1998)
- Symptom: Rough idle, misfire, hard start, raw fuel smell
- Fix: Replace the MPFI central sequential fuel injection unit (CSFI) — also called the spider injector
Oil Pressure Sender Failure
- Symptom: Oil pressure gauge reading zero or erratic
- Fix: Replace the oil pressure sending unit behind the distributor — this is the single most common gauge failure on OBS trucks
Distributor Cap & Rotor Wear
- Symptom: Rough idle, hesitation, misfire
- Fix: Replace cap and rotor every 30K miles on distributor-based engines; check the coil wire as well
Transmission Issues
4L60E (1993–1998)
3rd to 4th Gear Slip / No 4th Gear
- Cause: Worn 3-4 clutch pack; this is the single most common 4L60E failure
- Fix: Rebuild or replacement trans
Converter Shudder
- Symptom: Vibration at light throttle 40–55 MPH (TCC engagement)
- Fix: Drain and refill with Dexron VI; add Lubegard Shudder Fixx
4L80E (Heavy Duty trucks)
Generally more durable. Pressure control solenoid failure is a common electrical issue.
Electrical Issues
Instrument Cluster Problems
- Tachometer failure is common — often a cold solder joint inside the cluster
- Speedometer inaccuracy — check speed sensor first
Power Window Motor Failure
- Regulator arms wear out; replacement regulators are inexpensive and a 1-hour DIY job
Blower Motor Resistor
- Fan only works on high speed = dead resistor. Located behind the glove box.
Suspension Issues
Front Ball Joint Wear
- Symptom: Clunking over bumps, wandering steering
- Fix: Upper and lower ball joints — both sides while you’re in there
Front Coil Spring Sag
- On 2WD models: front end sits low after 150K+ miles
- Fix: Replacement coil springs or quick-strut upgrade
Body & Rust Issues
Cab Corner Rust
- The OBS body is particularly prone to cab corner rot — check lower rear of both doors
- Reproduction cab corners are widely available
Tailgate Cable Failure
- Cables stretch and fray; often fall out unexpectedly
- Easy fix: replacement tailgate cables
Cooling System
Intake Manifold Gasket Failure (5.7L/5.0L)
- Symptom: Coolant in oil, overheating, white exhaust smoke
- Fix: Fel-Pro MS 92211 intake manifold gasket set — use the updated gasket design
This is one of the most expensive repairs to ignore — coolant mixing with oil destroys bearings fast.
Preventive Maintenance Priorities
- Check intake manifold gaskets at 100K (5.7L)
- Service 4L60E fluid at 60K (don’t flush — drain and refill)
- Replace distributor cap and rotor every 30K
- Inspect ball joints and front end at 100K
- Replace coolant every 2 years (green Dexcool alternative preferred)
