After 25–35+ years, the front end on a 1988–1998 GMT400 truck is likely worn. A front end rebuild restores steering precision and removes the slop that develops over time. Here’s the complete parts list.
Signs the Front End Needs Work:
- Loose, wandering steering
- Clunking or knocking over bumps
- Tire wear on the inside or outside edges
- Alignment can’t be set to spec
- Shimmy or wobble at highway speeds
Front End Components to Inspect/Replace:
Tie Rod Ends (Inner and Outer):
These connect the steering rack/box to the wheel knuckles. Wear creates looseness and imprecise steering. Test by grabbing the tire at 9 and 3 o’clock and checking for play.
Ball Joints (Upper and Lower):
The ball joints allow the wheel knuckle to pivot. Test by lifting the vehicle and checking for vertical play at the wheel.
Pitman Arm and Idler Arm (on vehicles with steering box):
The K1500 4WD uses a steering box/drag link/pitman arm system. The idler arm is a common wear item.
Wheel Bearings:
The GMT400 4WD uses manual locking hubs with wheel bearings that wear over time. Check for play and rumble noise.
Upper Control Arms (4WD):
The 4WD K1500 uses upper and lower control arms. Check the ball joint at the upper arm.
Recommended Products:
- Bilstein 5100 Front Shocks – Silverado/Sierra – While doing the front end, upgrade to Bilstein shocks for improved ride and handling.
- MOOG tie rod ends and ball joints are OEM quality for budget-conscious builds
- ACDelco Professional is OEM spec
Full Rebuild Cost:
- DIY parts (tie rod ends, ball joints, idler arm, pitman arm): $300–$600
- Professional labor + alignment: $400–$800
How many miles does your GMT400 have? When did you last do front end work?
