GMT400 Double Din (Reversion Raceworks)
GMT400 “double din” without cutting the dash — Reversion Raceworks 1.5 Din setup
If you’ve looked into double din radios on a GMT400, you already know the problem.
True double din = cutting the dash. No going back.
This is the clean workaround.
What this setup actually is
Reversion Raceworks doesn’t do a true double din.
It’s a 1.5 DIN touchscreen kit that gives you the same look and function.
  • Designed for 95–98 OBS / GMT400
  • Uses a custom bracket + radio combo
  • Drops into the factory location
  • No trimming, no hacking the bezel
End result: looks like a factory touchscreen.
Why this is the move
  • Keeps your dash intact (biggest win)
  • Modern features: CarPlay / Android Auto
  • OEM-style fitment, no weird gaps
  • Fully reversible if you ever go back to stock
Most universal double din kits:
  • Require cutting the lower dash structure
  • Never fit quite right
  • Look aftermarket
This solves all of that.
Link here.
Install reality
Not hard.
  • Plug-and-play style harness (still need to wire it)
  • Mounts into factory radio location
  • About 30–60 minutes if you’ve done radios before
Minor notes:
  • Some guys report slight sleeve movement → fixed with foam tape
  • Fitment to the bracket is solid
The tradeoff
It’s not a true double din chassis.
  • Smaller body behind the screen
  • Screen size depends on the unit
  • No big 9–10” floating display look
But:
You get 90% of the functionality
Without destroying the dash
Bottom line
If you want:
  • Clean interior
  • Modern tech
  • No permanent mods
This is the best option for GMT400 right now.
If you want a true double din:
You’re cutting the dash. No workaround.
