GMT400 Diesel Swap – 6.5 vs Cummins Conversion
Converting your 1988–1998 GMT400 to diesel power is a popular upgrade for towing-focused owners. The two main options are the factory-compatible 6.5L diesel or a Cummins swap. Here’s how they compare.
The Factory Option: 6.2L/6.5L Detroit Diesel
GM used the 6.5L diesel (and earlier 6.2L) in many GMT400 trucks from the factory. If your truck didn’t come with a diesel, swapping to the 6.5L is the most straightforward option.
6.5L Diesel Strengths:
  • Direct bolt-in using factory motor mounts and transmission
  • All factory wiring harness connections are compatible
  • Keeps the 4L80E transmission
  • Relatively cheap donor engine
6.5L Diesel Weaknesses:
  • Only about 180 HP/360 ft-lbs stock
  • PMD (Pump Mounted Driver) failure is a well-known issue
  • Not as powerful or reliable as a Cummins
The Popular Alternative: Cummins 12V Swap
The 5.9L 12-Valve Cummins (from 1989–1998 Dodge trucks) is the most popular diesel swap into GMT400 trucks. The Cummins is mechanical injection, making it very reliable.
Cummins Strengths:
  • Significantly more power potential (stock 180 HP, easily 400+ HP with mods)
  • Mechanical injection = extremely reliable
  • Does not need electricity to run the injection system
  • Massive power upgrade over the 6.5L
Cummins Challenges:
  • Requires custom motor mounts and transmission adapters
  • Longer engine (requires firewall modification)
  • Transmission adapter needed (Cummins to 4L80E or NV5600)
  • More expensive conversion ($3,000–$8,000+ in parts)
The 6.5L PMD Fix:
If you’re keeping the 6.5L, the PMD relocation kit is a must. The PMD overheats mounted on the injection pump and causes no-start issues. Relocate it away from engine heat.
Lubegard Instant Shudder Fixx – Useful for the 4L80E that often pairs with diesel GMT400s.
What diesel setup are you running or planning for your GMT400?
